Warning message
SSH on Cat5000 ????
Jan 8th, 2004
I have a supervisor II with 2x 100Mb Sc MMF (32mb)
Is it possible to use such a software version that caters for SSH version 1 (or 2).
I have just upgraded to 4.5.2.
I have read you require at least version 6.1 (K9)
I have found the following link:
http://www.cisco.com/cgi-bin/Software/SWSearch/SWSearch_results.cgi/SWSearch.txt?isChild=true&dir_delimiter=contains&dir_pattern=5000&file_delimiter=contains&file_pattern=&list_format=html
Which includes an SSH capable image for sup2 5000, however when i try to copy from my TFTP server the file is not recognised.
My TFTP server is ok, i have just used the same process to upgrade as i said above.
Do i need to upgrade something else or go in stages?
Please help.
Kindest Regards...
Kai Nicholls
skarundi Thu, 01/08/2004 - 14:36
  • Bronze, 100 points or more
According to the release notes the catalyst 5000 supervisor II is not supported in 6.x , only the supervisor II G, supervisor III and supervisor III G.
Check out the catalyst 5000 6.x release note section titled "Release 6.x Supervisor Engine Support Matrix"
