Warning message
DMVPN: Timers??? (NHRP, IPsec, EIGRP)
Jan 9th, 2004
I've a DMVPN up and running but if a node gets an other IP-address of the ISP or a router (node or hub) reloads it takes 2 - 3 hours before a new connection is established.
I believe it's a timer problem (especially IPsec) But there are a lot of timers (and they influend each other)
Node config::
crypto ipsec transform-set transform_dk esp-3des esp-sha-hmac
mode transport
crypto ipsec profile profile_dk
set security-association lifetime second 86400
set security-association idle-time 150
set transform-set transform_dk
interface Tunnel1
description --- DMVPN tunnel ---
ip address 10.132.136.1 255.255.192.0
no ip redirects
ip mtu 1428
ip nhrp authentication password
ip nhrp map multicast 194.x.x.25
ip nhrp map 10.132.128.1 194.x.x.25
ip nhrp network-id 1000
ip nhrp holdtime 300
ip nhrp nhs 10.132.128.1
ip hello-interval eigrp 1 30
ip hold-time eigrp 1 65
qos pre-classify
tunnel source BVI1
tunnel mode gre multipoint
tunnel key 1000
tunnel protection ipsec profile profile_dk
Which are the optimal values for next timers???
I haven't found a description from how these timers influend each other. Is there a description?
