01-12-2004 11:39 AM - edited 03-02-2019 12:49 PM
fellow networkers
i have a 2900 xl switch..where i cant ping pcs if i put them on 2900 but if i shift them to 1900 .,they all ping..i accept could be a duplex/speed mismatch of ports..i have compaqs, even if i erase all the config..just blank switch..still teh problem persists
enlighten pls
shukky
01-14-2004 05:37 AM
If you are sure about the blank switch and having all ports enables auto/auto in the right vlan and are not able to ping even the management interface configured in the same vlan / ip net, i would say it's broken. Some of these switches seem to have faulty components witch could cause these simtoms.
pls read
http://www.cisco.com/warp/public/473/164.html
http://www.cisco.com/warp/public/770/fn26174.shtml
Duplex fault would just show bad troughput but usually not all frames are lost under low traffic conditions, losses start going up if traffic increases.
01-16-2004 01:44 AM
thank you , ill find out the solution now
