Warning message
what is the true installation order for VMS 2.2 Update 1 ?
Jan 15th, 2004
Installing and getting VMS 2.2 up and running is a little complex, especially because of various prerequisites ;
Can anyone clarify in which order should be installed VMS 2.2 Update 1 ?
I have found 2 differents documents about VMS 2.2 Update 1 on the CISCO web which are a little contradictory ;
Here they are :
1) Readme for CiscoWorks VMS 2.2 Update 1
(URL : http://www.cisco.com/en/US/partner/products/sw/cscowork/ps2330/prod_release_note09186a00801ca636.html ):
this document states the following installation order :
a) VMS 2.2 and all the requested components, such as FW MC
b) FW MC 1.2.2
c) VMS 2.2 Update 1
2) Quick Start Guide for the VPN/Security Management Solution 2.2
(URL : http://www.cisco.com/en/US/partner/products/sw/cscowork/ps2330/products_quick_start09186a00801e55d5.html )
This document states that VMS 2.2 SP2 should be installed before installing any VMS components (such as FW MC)
Questions :
1) is VMS 2.2 SP2 part of VMS 2.2 Update 1 package ?
if yes, the 2nd document listed above, seems contradictory compared with the 1st one
if no, where can I get this VMS 2.2 SP2 on the CISCO Web ?
2) I have received VMS 2.2 package, without VMS 2.2 Update 1 package ; the order of installation I have used is :
a) VMS 2.2 Common Services
b) FW MC 1.1.3 (included in the shipped VMS package),
then to try to solve different problems, I have downloaded FW MC 1.2.2 and VMS 2.2 Update 1 from CISCO Web, and installed them in the following order :
c) FW MC 1.2.2
d) VMS 2.2 Update 1
Is this the right order (as described in the 1st document listed above) ?
if not, what is the right order ?
thanks for your help
benhur.p Wed, 01/21/2004 - 05:07
I followed the first Procedure and have no issues...
