Warning message
PIX balancing with CSMs on both ends...
Jan 16th, 2004
I'm preparing configurations for CSM oriented solution. Now i'm testing PIX load balancing using CSM. For simplisity there is situation like in:
Configuring Regular Firewall Load Balancing, page 5-17
where we got:
Internet -> [email protected] -> PIXes -> [email protected] -> DMZs
where DMZs could be internet users, intranet with FW-1 and so on.
I had configuration exactly as in mentioned document:
cat6509 (Internet side):
module ContentSwitchingModule 5
vlan 100 client
ip address 100.0.0.25 255.255.255.0
gateway 100.0.0.13
vlan 101 server
alias 100.0.0.20 255.255.255.0
serverfarm FORWARD-SF
no nat server
no nat client
predictor forward
serverfarm INSEC-SF
no nat server
no nat client
predictor hash address source
real 100.0.0.3
inservice
real 100.0.0.4
inservice
vserver FORWARD-VS
virtual 0.0.0.0 0.0.0.0 any
vlan 101
persistent rebalance
inservice
vserver INSEC-VS
virtual 200.0.0.0 255.255.255.0 any
vlan 100
serverfarm INSEC-SF
inservice
interface Vlan100
ip address 100.0.0.13 255.255.255.0
ip route 10.0.0.0 255.0.0.0 100.0.0.20
ip route 200.0.0.0 255.0.0.0 100.0.0.20
cat6509:DMZs/intRAnet side:
vlan 201 server
ip address 200.0.0.26 255.255.255.0
alias 200.0.0.20 255.255.255.0
vlan 20 server
ip address 10.1.0.26 255.255.255.0
vlan 200 client
serverfarm GENERIC-SF
nat server
no nat client
real 10.1.0.66
inservice
serverfarm SEC-SF
no nat server
no nat client
predictor hash address destination
real 200.0.0.3
inservice
real 200.0.0.4
inservice
vserver GENERIC-VS
virtual 200.0.0.127 tcp 0
vlan 201
inservice
vserver SEC-20-VS
vlan 20
serverfarm SEC-SF
inservice
vserver SEC-200-VS
serverfarm SEC-SF
inservice
VLANs:
100 - Internet
101 - PIX Outisdes
201 - PIX Insides
200 - sample DMZ with users..
20 - sample DMZ with servers
Internet need access to [email protected]
Hosts from VLAN 200 and VL 20 need access to Internet
Trafice beetwen DMZs need to be allowed
Gilles Dufour Fri, 01/16/2004 - 05:39
  • Cisco Employee,
I see one problem already.
Your MSFC has an interface vlan 100 and a static route pointing at address 100.0.0.20 which is the alias in vlan 101.
Your MSFC probably can't ping 100.0.0.20
You should configure an alias in vlan 100 of the CSM and have the MSFC pointing to this alias.
Also, the 2nd CSM does not have a serverfarm FORWARD.
You will need one normally to forward traffic to your local subnet without loadbalancing.
[what you configured is possible but I'm not sure this is the result you are expecting]
Gilles.
