adsl wic & bad buffer problems !!
Jan 19th, 2004
Hello all,
I have recently purchased a cisco 2600 and an adsl wic (wic1-adsl). I am have big problems getting the adsl wic to work.
The background is :
cisco ios : 12.2(8)T10
When i install the card i cannot see it in the running config and i see bad buffer error on boot.Upon boot I get:
Unknown WIC in slot(0/0), wic card has an unknown id of 0x2E
00:00:07: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
00:00:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, chang
ed state to downtdm_eadi_post_configs: TDM Backplane not enabled
00:00:36: %IP-5-WEBINST_KILL: Terminating DNS process
00:00:37: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state to administr
atively down
00:00:37: %SYS-5-RESTART: System restarted --
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(8)T10, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 30-May-03 02:45 by kellythw
00:00:37: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold star
t
00:00:37: %SYS-2-GETBUF: Bad getbuffer, bytes= 68450369
-Process= "Init", ipl= 0, pid= 2
-Traceback= 80378188 80816BFC 80816AE8 8041BBE4 8041BDE0 8041C0D8 80314308 803E9
1E4
As you can see the wic0/0 (where the adsl wic is) is not recognised. However if i do a sh diag i can see it:
WIC Slot 0:
DSL SAR (ADSL)
Hardware Revision : 2.3
Part Number : 73-4771-08
Board Revision : A0
Deviation Number : 0-0
Fab Version : 05
PCB Serial Number : JAB06150A35
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
EEPROM format version 4
EEPROM contents (hex):
Can anyone point me in the right direction? I have tried on 3 different routers and tried 2 diferent adsl cards. Do i have an ios problem or something?
thanks in advance..
Richard
Georg Pauwen Mon, 01/19/2004 - 05:02
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
Hello Richard,
before looking any further, here are the IOS versions the Cisco Software Advisor says are required:
12.1(5)YB, 12.2(4)T, 12.2(11)YT, 12.3(1)
You might want to try one of those and see if your card gets detected.
GP
