startup-config problem
Jan 21st, 2004
when i issue any command that tries to access the startup-config, i get the warning message: %% Non-volatile configuration memory is being accessed, Try again later". What's causing this? what's the fix? can't find anything on the cisco website.
milan.kulik Thu, 01/22/2004 - 00:00
  • Red, 2250 points or more
which platform are you using?
I noticed something similar in the past on Cat4006.
The reason were some http server configurations and an CatOS bug.
The only solution was a switch reset.
But I also lost a part of the config.
So I strongly recommend an immediate running config backup!!!
Another possible reason might be a network management system failure. It might be trying to read the startup config all the time in a loop.
Milan
