Warning message
switch harware identification
Jan 21st, 2004
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP1A-2GE SAD04460J3K Hw : 7.0
Fw : 5.3(1)
Fw1: 5.4(2)
Sw : 7.2(2)
Sw1: 7.2(2)
What does Fw mean/used for & why they are 2 Fw -- Fw & Fw1..
thanks
Richard Burts Sun, 02/20/2011 - 20:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Ty
This is a very old thread to try to re-start. You probably would be better off to start a new thread and ask your question as a fresh issue.
In the context of the original post FW is FirmWare. We do not have enough information to give a good answer about fw and fw1. My guess is that there are two different modules/cards each with its own firmware but the display in the original post only contained the slot port model information for the slot with supervisor.
If you have a similar situation then perhaps you could post the output of show module from your switch? If we had a more complete output we might be able to give better answers.
Rick
