FE1,E1,PRI ISDN
Jan 24th, 2004
  • Bronze, 100 points or more
I want to know what's different between fractional E1 ,fractional PRI ISDN,E1 and PRI ISDN.
I would be appreciate if you help me.
M.A.Rad
mark-obrien Sat, 01/24/2004 - 13:59
1. Fractional E1 - An E1 interface is presented to your equipment. Only some of the channels are active, and they are point-to-point channels.
2. Fractional PRI ISDN - An E1 is presented to your equipment. One of the channels (15, I think - I'm a Yank so I'm not sure) acts as the D channel for signalling between your equipment and the switch. Some, but not all (therefore "fractional") of the channels are used for end-to-end data on a per-call basis. These are called B channels
3. E1 - An E1 is presented to your equipment. All channels are available for your data on a point-to-point basis.
4. PRI ISDN - Same as 2 above, but all channels except the D channel are available as B channels.
Mark
mehrdad Sat, 01/24/2004 - 22:23
Thank you for your reply.
Could you please tell me , what's different between an E1 line and an E1 channelized line?
M.A.Rad
mark-obrien Sun, 01/25/2004 - 07:23
An E1 line is simply 2 Mbps of data. E1 Channelized formats that 2 Mbps line in a standard fashion so that there are 30 64kbps channels on it. A multiplexer can use this format to turn up a number of these channels to the user.
Mark
