Warning message
Simple DNS config Question....
Jan 24th, 2004
Hi all. I have not had to mess with my 1605R router in some time and have forgotten how to change my existing two DNS numbers to two new DNS numbers that my ISP is switching us to.
I can telnet to my router and get logged on. I type in <enable> and then can do a <show run>...I know that I need to be in configure mode, but cannot remember the command line to get the old ones out and the new DNS numbers in the config.
It's a very simple set up. Cable mode to the router and then the 2nd interface from router goes to a switch where the feed is shared out to about 8 machines.
It's already set up....I just need to change my DNS numbers on the outside interface....
the dedicated IP, subnet and default gateway all remain as they are now.
Thanks All....
Bryan
Overall Rating: 5 (2 ratings)
mark-obrien Sat, 01/24/2004 - 14:17
  • Bronze, 100 points or more
Here are the commands you need:
no ip name-server oldaddress1 oldaddress1
ip name-server newaddress1 newaddress2
Good luck.
Mark
atomicweight Sat, 01/24/2004 - 22:51
Ok, cool. I took the numbers out and put the new ones in..no problem. Last question..I think. I notice below there in the DHCP pool that I still see the dns-server old numbers still showing up. Do I need to change these as well?
Thanks so much for replying...
out here..
bryan
mark-obrien Sun, 01/25/2004 - 07:25
Yes you do. Those addresses in the DHCP pool are the DNS servers that your DHCP clients will use. If they have the wrong server(s), they will not resolve names on the internet, or your internal network for that matter.
Mark
atomicweight Sun, 01/25/2004 - 10:23
Hey,thanks for writing. I figured I would have to change them. This is probably the last thing I need. I have changed the ip name-server addresses. What command will let me take the existing DNS numbers in the DHCP pool out and what command will let me enter the two new one?
Thanks Again...
After I change these numbers, I'll put the router on the network and see if I can pass the traffic again..
Take Care
bryan
mark-obrien Sun, 01/25/2004 - 13:02
Bryan,
Enter these commands:
ip dhcp pool (existing pool name)
no dns-server (server address1) (server address2)...
dns-server (new address1) (new address2)...
^z
Don't forget to save your configuration with the command "copy runn start" so that if the router is rebooted you have these new commands in service.
Mark
atomicweight Tue, 01/27/2004 - 13:36
Hi Mark and thanks for all your help. I changed the DNS numbers in both areas mentioned above just fine. Did a copy run start and got that all done. I returned the router to the network at Branch B library. All machines can now access the Internet just fine. However, I can now not see Library A's 2 websites nor can I connect to the databae to checkout books.
If the ISP (charter cable) only changed the DNS numbers and I made only two changes to the config (that was working just fine before) concerning the DNS numbers and you have been helping me with, why can I now not see my own web server and database located at Branch A?
I have a cable modem at Branch B and a cable modem at Branch A.
I took the router off the network and let everything get info from charters network via my switch out to the cable modem. Everything worked fine. I can only have 3 machines behind the switch working at one time as per Charter's allocation for address's, so that is why I need the router there as we have 6 machines that need to have Internet access. So, I do need the router.
Here is a copy of my current config...if you dont' mind...would you or someone take a look at it and see why I can't pass traffice from the router to Branch A?
The router has this address on it 24.197.19.XXX. My two web servers have the same octets sequence as above with the ending octets being different of course. So, in other words, the router can pass and ping to all address except its own network??
Does anyone see anything in the current config that would cause the router with 24.197.19.xxx on the outside interface not to be able to pass traffic to my two web servers with 24.197.19.xxx numbers respectively?
When I ping from the router to the outside world, I get a return no problem...when I try to ping 24.197.19.xxx, I get time outs??
Here is the current config...
Current configuration : 1219 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname apollo
logging rate-limit console 10 except errors
enable secret xxxxx
username xxxx password xxxxx
ip subnet-zero
no ip source-route
no ip finger
ip name-server 209.225.8.42
ip name-server 24.240.141.226
ip dhcp pool DHCPPoolLAN_1
network 192.168.100.0 255.255.255.0
--More—
default-router 192.168.100.1
dns-server 209.225.x.x x.x.141.226
interface Ethernet0
ip address 24.x.x.x x.255.252.0
no ip proxy-arp
ip nat outside
ip rip send version 1 2
ip rip receive version 1 2
no ip route-cache
interface Ethernet1
ip address 192.168.100.1 255.255.255.0
no ip proxy-arp
ip nat inside
no ip route-cache
router rip
--More—
no ip route-cache
router rip
network 24.0.0.0
ip nat inside source list 11 interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 24.197.16.1
no ip http server
access-list 11 permit 192.168.100.0 0.0.0.255
line con 0
exec-timeout 0 0
transport input none
line vty 0 4
exec-timeout 0 0
login local
end
atomicweight Tue, 01/27/2004 - 13:40
Hey, I wanted to add this too.
The correct DNS numbers are these...
209.225.8.42
24.240.141.226
The gateway that should be being used is
24.197.16.1
Thanks again for all your help!!
Bryan
