Warning message
3500 Switch is giving %RTD-1-LINK_FLAP
Jan 26th, 2004
we have problem connecting 3550 emi switch with 3500 switch In show logs i am get %RTD-1-LINK_FLAP error in 3500 series switch but i am not get these message in 3550 emi Switch And i have attached the show log of 3500 series switch.
Nagalakshmi
nagalakshmi_n2000 Mon, 01/26/2004 - 03:57
RTD-1-LINK_FLAP [chars] link down/up [dec] times per min
Explanation This message indicates that an excessive number of link down-up events has been noticed on this interface: [chars] is the interface, and [dec] is the number of times the link goes up and down. This might be the result of reconfiguring the port, or it might indicate a faulty device at the other end of the connection.
Action If someone is reconfiguring the interface or device at the other side of the interface, ignore this message. However, if no one is manipulating the interface or device at the other end of the interface, it is likely that the Ethernet transceiver at one end of the link is faulty and should be replaced.
But what is the soluation for these problem the link is going down very offen and it is not communacting to other switch
dave.keith Tue, 01/27/2004 - 12:24
  • Bronze, 100 points or more
The few times I've seen that message have all turned out to be physical cable problems. Have you replaced the inter-switch patch cable ?
