ahvn Mon, 01/26/2004 - 22:21
I think yes, NM2E2W supports wic-2T card
Rgds
Homin
jolmo Tue, 01/27/2004 - 00:35
  • Silver, 250 points or more
Hi Delon
According to:
http://www.cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a00800b0858.shtml#plat
in 3600 series WIC-2T is not supported with Ethernet Network Modules:
"The NM-1E2W, NM-1E1R2W, and NM-2E2W Network Modules do not have enough performance power to support the WIC-2T due to hardware limitations."
You will need a Fast Ethernet NM to support WIC-2T in a 3600 series
ahvn Tue, 01/27/2004 - 21:34
The previous answer is right.NM-2W or NM-FE modules will support WIC-2T.Sorry for the wrong assumption.
Rgds
Homin
