Warning message
Inventory Custom report
Jan 27th, 2004
Running cisco works 5th edition, with Resource manager 3.4, got around 500 router and switchs in the network.
Is there a way to create a custom report as follows:
*Device Name*Device Type*Device Serial Number*Module or Modules Type* Module Serial Number*Dram size*Flash Size*.
M
rmushtaq Tue, 01/27/2004 - 10:25
  • Blue, 1500 points or more
You can either create a Custom Report for this or look at Detailed Device Report in RME.
mmali Tue, 01/27/2004 - 21:15
Salaam,
You are right but detailed device report gives you lot of information,
I want to generate a specific report.
like Device Name*Device Type*Serial Number*Modules * Modules Serial Number*.
rmushtaq Wed, 01/28/2004 - 11:07
Look at the Custom Reports or alternately can use DEE to do the export and then filter out the unwanted stuff from it.
axfalk Tue, 02/10/2004 - 08:43
Pardon me for jumping in. I am also looking to create an inventory report that would display the model number and the serial number of our Cat-2980G switches. The Custom Report does not have the report type that would include both, the model number and the serial number. How do you go about filtering out the unwanted stuff from the DEE since the Admin folder does not have the DEE setup?
Thanks.
_ Alex
axfalk Wed, 02/11/2004 - 06:22
Thanks for your response. Did you use Crystal Reports in conjunction with DDE or Custim Reports from RME?
_ Alex
