LAN-based failover
Jan 28th, 2004
Regarding LAN-based failover in PIX'es
- is it possible and supported, having multiple failover installation in same subnet/vlan or should each set of PIX'es have their own subnet/VLAN ?
Thanks in advance.
Christian
scoclayton Wed, 01/28/2004 - 08:00
  • Gold, 750 points or more
Christian,
Same subnet - No
Same Vlan - Yes although not advised
Each interface on the PIX must be in a unique subnet. You can however connect multiple interfaces to the same backend VLAN but I don't know why you would really want to. To be ultra secure, each interface on the primary PIX *should* connect to the stand-by PIX via a seperate switch. In some cases, this is not feasible however so creating seperate VLAN's on 1 or 2 physical switches will also work.
Hope this makes sense.
Scott
