Warning message
1721 router configuration
Jan 29th, 2004
Im am trying to configure a 1721 router. It was configured before. I am not able to enter any commands such as end, enable, configure.... I get the prompt monitor:command "exit" not found. The next line comes up as rommon 3 > and anything entered gets the same response....What am I doing wrong??? I turned off power and restarted it to see if it would reset, but no luck.
