PIX enable authentication with Freeware TACACS+
Jan 30th, 2004
I am running PIX 6.3 with Freeware TACACS+.The TACACS+ server is working fine with all routers in my network but i have problems when trying to authenticate users with the PIX, especially with enable authentication. The configuration of the TACACS+ server for the user is:
user {
login = cleartext " "
and the message in the tacacs log file is
tac_plus: enable query rejected
Any help would be greatly appreciated.
awaheed Sat, 01/31/2004 - 13:41
  • Cisco Employee,
Hi Iganeva,
Just wanted to let you know that for the earlier code's which worked with the PIX, we have seen it to work with the following config in the freeware TACACS+:
user = pixtest {
login = cleartext cisco123
service = enable {
Now that said, the way the PIX used to allow Login, was changed in the later codes, and that might have broken the implementation for the Feeware TACSCS+
Details: www.cisco.com/support/bugtools/
CSCdm47044
Externally found enhancement defect: Verified (V)
PIX enable authentication only requires login password.
Also, as its a Freeware you might have to can run debug on the freeware server to see if they can reverse-engineer the free code to make it work.
hope this helps,
Aamir
