Warning message
GRE tunnles and dynamic routing
Jan 30th, 2004
I am putting together an IP WAN with more than 50 sites using dynamic EIGRP routing protocol across GRE tunnels . At this time all of my GRE tunnle IP addresses show up in the EIGRP routing table. Is there a configuration that would allow dynamic routing of my sites but not have the GRE IP addresses show up in the routing table?
I have tryed static routing of the GRE tunnels but was unable to make it work the way I would like.
nihanth Fri, 01/30/2004 - 12:53
When we are using eigrp with gre tunnel, we should advertise tunnel network to eigrp. we should not use static routing .
ruwhite Sun, 02/01/2004 - 03:46
  • Gold, 750 points or more
You could put the tunnels into EIGRP, and then filter them out at the "hub" router towards the core of the network. If the tunnels are all numbered in a single contiguous address block, a single link access list applied as a distribute list should work.
Russ.W
