ASK THE EXPERT- TROUBLESHOOTING ACCESS SERVER CONNECTIVITY ISSUES
Jan 30th, 2004
  • Gold, 750 points or more
Welcome to the Cisco Networking Professionals Ask the Expert conversation. This is an opportunity to discuss Troubleshooting Access Server Connectivity Issues with Cisco expert Mak Chitale. Mak is a Customer Support Engineer at the Technical Assistance Center - TAC in San Jose. His current responsibilities include escalations in which he troubleshoots complex issues, provides training, and authors documentation. His areas of expertise are Configuration and Troubleshooting of Access Servers such as PPP and VPDN. Makarand is a CCIE 7071 for ISP Dial. He is the World Wide SME (Subject Matter Expert) for Access technology which involves improving the web documentation. Makarand holds a Bachelor Degree in Marine Engineering (Mechanical / Electrical & Telecommunication Engineering). Remember to use the rating system to let Mak know if you have received an adequate response.
Mak might not be able to answer each question due to the volume expected during this event. Our moderators will post many of the unanswered questions in other discussion forums shortly after the event. This event lasts through February 13. Visit this forum often to view responses to your questions and the questions of other community members.
Overall Rating: 4 (1 ratings)
kfsaini Sun, 02/01/2004 - 18:57
Hi, I am trying to config WIC 1DSU 56k on 2621. Can you please tell me how i would be able to config the router so it has dedicated access to internet thru the local ISP using the 56k module.
thanks,
Singh
makchitale Mon, 02/02/2004 - 22:56
  • Silver, 250 points or more
The below link has useful info on how to configure the 2600 router with WIC-DSU-56k card,
http://cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a0080093c56.shtml
For additional info on this card:
http://cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a00800a99cc.shtml
Please let me know if that helps or else I will create a config for you & post the same.
Thanks, Mak.
PAUL TRIVINO Mon, 02/02/2004 - 15:56
  • Bronze, 100 points or more
I'm not clear on how the "Ask the Expert" event is supposed to work. I have a Post "Windows TERMINAL Screen garbage - PPP Dialin" on the Remote Access forum, one gentleman posted a reply asking for more info, but that's it. Am I supposed to post queries for the Event under this thread? Or will Mak be looking at all issues on the Forum? Could you clarify this?
makchitale Mon, 02/02/2004 - 23:17
Under the interface Group-async 1 we have "asyn mode dedicated"... since we are using a post dialup window setting on the client end please change the same to "asyn mode interactive". When we configure for dedicated that means we will start a PPP session (vs a exec session followed by the PPP)...the garbage we see on client screen is the LCP packets from the Cisco3700. NOTE: unless we authenticate or hit the DONE button or type PPP we have not transferred the PPP stack to the client OS (XP/2k etc).
interface Group-Async1
async mode dedicated <==change to async mode interactive
group-range 65 88
line 65 88
autoselect during-login
autoselect ppp
Coming to on how the "Ask the Expert" event is supposed to work. ...all questions posted under this event will be answered by me, other are most welcome to do so too. In short questions posted here will get a response from me if it lies in my field of expertise.
Thanks, Mak.
PAUL TRIVINO Tue, 02/03/2004 - 12:21
OK, Mak, here's my question, copied from its separate posting:
Following the "Cfg'ing a C3600 Rtr w/T1/E1 and Digital Modem Net Mod" document, I'm trying to configure a C3725MBUNDLE-24DM box for dialin Remote Access. Basic config is fine:
version 12.2
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname NETWRZ01
logging buffered 65535 debugging
logging monitor informational
enable secret 5
enable password 7
username xxxx password xxxx
! password is 'user'
clock timezone PST -8
clock summer-time PDT recurring
ip subnet-zero
async-bootp dns-server 10.8.236.22
async-bootp nbns-server 10.8.236.22
isdn switch-type primary-ni
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface FastEthernet0/0
ip address 10.15.254.120 255.255.255.0
speed 100
full-duplex
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:23
no ip address
encapsulation ppp
isdn incoming-voice modem
ip unnumbered FastEthernet0/0
encapsulation ppp
dialer in-band
dialer idle-timeout 300
dialer-group 1
peer default ip address pool ras-pool
no keepalive
ppp authentication chap pap
group-range 65 88
router eigrp 110
network 10.15.254.0 0.0.0.255
no auto-summary
ip local pool ras-pool 10.15.254.121 10.15.254.144
ip classless
ip default-network 0.0.0.0
ip http server
dialer-list 1 protocol ip permit
snmp-server community RW
snmp-server enable traps tty
line con 0
exec-timeout 15 0
password 7
login
line 65 88
no flush-at-activation
modem InOut
transport input all
autoselect ppp
line aux 0
line vty 0 4
exec-timeout 15 0
password 7
login
ntp server x.x.x.x
ntp server x.x.x.x prefer
end
The Windows Dial Up Networking profile specifies to "Show Terminal Window" on connect, which it does, but the terminal window shows garbage. BUT, I type the userid, Enter, and password and Enter, and the connection is established fine. For our users, I need the Terminal Window to work correctly, plus we have a script which waits for "ogin:" and enters the users LoginID, etc. etc.
The clients are XP laptops. We're trying to make a seamless switch from a Lucent/Ascend MAX unit to the C3725. Further information: the "garbage" on the screen *looks like* a data/stops bits mismatch (E/7/1 vs N/8/1) - I say this because the same patter of characters repeats, as if it's a repeating prompt. But I haven't the foggiest idea how to fix that in this scenario. No one in the Laptop or Desktop support groups (at my company) can tell me what kind of terminal is emulated by this window, nor does the Windows XP "Help" have information on it (surprise, surprise!).
makchitale Tue, 02/03/2004 - 14:44
I went through the thread before responding earlier..resending the same:
group-range 65 88
line 65 88
autoselect ppp
Thanks, Mak.
PAUL TRIVINO Wed, 02/04/2004 - 15:05
Mak, that worked a treat. I had this before but when I saw the "NETWRZ01>" prompt, I thought I could only access the router itself - I did not understand that I could enter "ppp" and get the session started. Thanx!
josephqiu Tue, 02/03/2004 - 07:21
Hi, I have a question about AS5200. We use an AS5200 as RA server for dial-up connections. There is only 1 Ethernet port on the server, which is an AUI port. The server is connected to a Catalyst switch and the link between them is running 10MB and Half-duplex. Recently we found the server performance is not good. Dial-up users complain about slow response although they're just using Telnet terminals. Telneting from campus network to AS5200 itself is also very slow. Sometimes it takes upto 30 seconds to see the content of "sh int e0" command. There's about 14% packet loss from campus network to that server. But no packet loss is detected upto that Catalyst switch.
Actually, we only have 10 users dialing up at peak hours. Ethernet port traffic is only around 400Kbps on average. Average CPU usage is around 25% with peak 35-40%. Memory usage is about 55%. There're some collisions and deferred packets in Ethernet output traffic. But I believe it's just because we're running half-duplex.
So, please advice what's the possible reason for the bad performance of this AS5200, even all users are just using Telnet sessions.
By the way, IOS version: 11.2(10)P.
Thanks a lot!
-Joseph-
makchitale Tue, 02/03/2004 - 15:11
From the descrition above it appears that it's not just an issue with dialup users but even users telnetting into the as5200 through the LAN side, correct?
If the CPU looks ok then we could be seeing some memory related issue, that is, memory leak/ memory allocation failures etc.
"show log" should give us some indication of the same. I wouldn't suspect an ethernet issue but it's always good to see if changing the cabling or port on the switch changes any thing performance wise.
I would also recommend upgrading to a 11.3/12.0 image depending on the flash/DRAM onboard.
Thanks, Mak.
hgru Thu, 02/05/2004 - 04:56
We are working her with ACS 3.0. It has always been working fine but all 221 users where in one group.
Now we decided to create one group per department with the same group settings as the currect group of 221 users and move the users to there own department groups.
After doing so the users cannot logging (via dailup) until there password is reset. This is no workable since they cannot change their password from a remote location.
We are using the Windows NT/2000 to authenicate.
Any ideas?
Hans
makchitale Thu, 02/05/2004 - 11:34
What kind of databse are we using, ACS or Windows databse?
If ACS database, moving between group from the GUI should not be an issue.
If using windows they we simply delete the users in ACS and it will dynamically created mapping once again when the request is forwarded from ACS to Win.
Thanks, Mak.
hgru Fri, 02/06/2004 - 01:01
We are using the windows database.
You mean that if I delete the user in ACS it will re-create the user when the user is doing a dailup. I would say it would fail then. Otherwise every user of the windows environment is automaticly allowed to dailin. And even if this would work how would they end up in the right ACS group?
Hans
makchitale Fri, 02/06/2004 - 13:28
You need to use the feature of database group mapping.
External user database->Database group mapping --> Windows Database -->Configure --> Select the domain --> Select the AD group --> Add mapping --> map the different groups in your organization to different ACS group.
Remaining group which you do not want to give dialin access at all can be mapped to "No Access" group.
Before you do make these changes, the users must be deleted from ACS database.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/csnt30/user/q.htm#56814
Thanks, Mak.
fdiaz83 Thu, 02/05/2004 - 20:29
Hey I was wondering if you knew anybody that could help me with this problem. Both of my routers hang when they should be booting up to the prompt.
Please keep in mind that I will not let me break (yes I am using the proper break sequence for my terminal emulator) and will not go to ROMMON or a Router> prompt.
System Bootstrap, Version 5.2(8a), RELEASE SOFTWAREVersion 2.0, NET2, BFE and GOSIP compliant.
Copyright (c) 1986-1995 by cisco Systems
1 Token Ring/IEEE 802.5 interf
2500 processor with 14336 Kbytes of main memoryial network interface(s)
F3: 7370472+108420+286116 at 0x3000060ration memory.
Restricted Rights Legendrocessor board System flash (Read ONLY
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS s
San Jose, California 95134-1706
IOS (tm) 2500 Software (C2500-AINR-L), Version 11.2(17), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Mon 04-Jan-99 17:55 by ashah
Image text-base: 0x03038204, data-base: 0x00001000
cisco 2500 (68030) processor (revision L) with 14336K/2048K bytes of memory.
Processor board ID 02968667, with hardware revision 00000000
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
1 Token Ring/IEEE 802.5 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
Press RETURN to get started!
%LINK-3-UPDOWN: Interface Serial0, changed state to down
%LINK-3-UPDOWN: Interface Serial1, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface TokenRing0, changed state to dow
n
%SYS-5-CONFIG_I: Configured from memory by console
%SYS-5-RESTART: System restarted --
%LINK-5-CHANGED: Interface Serial1, changed state to administratively down
%LINK-5-CHANGED: Interface TokenRing0, changed state to administratively down
makchitale Fri, 02/06/2004 - 09:43
I have seen this issue in the past where after reloading the router the console messages would stop showing up after the interface status are seen. I got around it by pressing the Function keys (F1...etc) on my laptop.
From the bootsequence it appears that the routers are actually up (off course could become unresponsive later due to memory issues or CPU spike). Can you telnet into them?
Can you try the same using another PC/ laptop?
I would like to know a little more on the sequence of events...where they working before, were any changes made prior to this behaviour.
Just a reference doc regarding the break sequence:
http://cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080174a34.shtml
Thanks, Mak.
fdiaz83 Sat, 02/07/2004 - 18:21
Mak,
Even after using another PC it still locks up after it boots, never going to the router prompt, even after pressing the fuction keys. I am only able to connect to the router via its console port.
I know that they were working prior to me receiving them, but since they are essentially a "hand me down" from someone studying for their CCNA I can not inform you of any changes made between the time they were working to the time I recieved them.
hgru Sun, 02/08/2004 - 11:24
When you do a "show version" what is teh setting of the config-register?
Hans
fdiaz83 Sun, 02/08/2004 - 17:35
Hans,
I can not even "break" into ROMMON. It seems that it will not accept any keystrokes. I know it is not the cable or the RJ45-DB9 adapter (they've been tested) and it's not the terminal settings because I've checked them. So right now I'm thoroughly stumped. I can't get into ROMMON and it seems as if it won't respond to the keystrokes. Any suggestions? Thanks.
hgru Mon, 02/09/2004 - 01:28
Oh sorry I was under the impression that it would boot normally. So you don't get a prompt after booting up and hitting the enter key.
Hmm, eh terminal emulation? Set it to vt1000 Wild guess. Also some terminal emulation programs do not support the CTRL-break properly. Do you have an onld dumb terminal available.
Hans
hgru Tue, 02/10/2004 - 02:57
Just wondering can you type any character so that you know your console cable and setiing are correct.
If not:
- Make sure that you are using the right serial port on your PC and that you are using the console connection.
- Try a different console cable
- Is you serial port enabled in the BIOS setup of you PC?
- Keep in mind that some of models of the lager switches uses different console cables.
Just some basic thoughts
igoneal Fri, 02/06/2004 - 04:16
pls my access-server with Async modules gives the result shown below
what is wrong in the configuration?
ACCESS-SERVER#show line 0 7
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 CTY - - - - - 0 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
1-7
Async33 is up (spoofing), line protocol is up (spoofing)
modem(slot/port):1/0, csm_state:IDLE_STATE,
bchan_num:-1 csm_status(0): CSM_STATUS_UNLOCKED
Hardware is MCOM Integrated Modem Controller
Interface is unnumbered. Using address of Loopback0 (192.168.0.253)
MTU 1500 bytes, BW 9 Kbit, DLY 100000 usec,
Encapsulation PPP, loopback not set
Keepalive not set
DTR is pulsed for 5 seconds on reset
LCP Closed, multilink Closed
Closed: IPCP
Last input never, output never, output hang never
Last clearing of "show interface" counters 01:07:00
Queueing strategy: fifo
Output queue: 0/10 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
Current configuration : 1468 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname ACCESS-SERVER
enable secret 5
enable password
username igoneal password 0
ip subnet-zero
interface Loopback0
ip address 192.168.0.253 255.255.255.0
ip address 81.199.6.148 255.255.255.0
speed 100
full-duplex
interface Serial0/0
no ip address
shutdown
clockrate 2000000
ip unnumbered Loopback0
encapsulation ppp
dialer in-band
dialer idle-timeout 14400
dialer-group 1
peer default ip address pool DIALIN
no fair-queue
ppp multilink
group-range 33 40
interface Group-Async2
encapsulation ppp
dialer in-band
dialer-group 2
no fair-queue
ppp multilink
group-range 65 72
ip local pool DIALIN 81.199.6.150 81.199.6.253
ip classless
no ip http server
line con 0
line 33 40
modem InOut
transport input all
line con 0
line 33 40
modem InOut
transport input all
autoselect ppp
flowcontrol hardware
line 65 72
modem InOut
transport input all
autoselect ppp
line aux 0
line vty 0 4
password
login
end
idoje Fri, 02/06/2004 - 06:37
Pls can someone help with the result I want the TTY to be in async mode, what do I do to this config? pls help
find the new config made some amendments but the tty is not in async mode ye what could be wrong
Current configuration : 3462 bytes
version 12.2
enable secret xxxxx
enable password xxxxx
username test password 0 test
ip subnet-zero
interface Loopback0
speed 100
full-duplex
interface Serial0/0
no ip address
shutdown
clockrate 2000000
interface Async33
encapsulation ppp
interface Async34
encapsulation ppp
interface Async35
encapsulation ppp
interface Async36
encapsulation ppp
interface Async37
encapsulation ppp
interface Async38
interface Async39
encapsulation ppp
interface Async40
encapsulation ppp
interface Async65
encapsulation ppp
no fair-queue
interface Async69
encapsulation ppp
no fair-queue
interface Async70
encapsulation ppp
no fair-queue
interface Async71
encapsulation ppp
no fair-queue
interface Async72
encapsulation ppp
no fair-queue
ip classless
no ip http server
line con 0
line 33 40
modem InOut
transport input all
autoselect ppp
line con 0
line 33 40
modem InOut
transport input all
autoselect ppp
line 65 72
modem InOut
transport input all
autoselect ppp
line aux 0
line vty 0 4
password xxxx
login
end
makchitale Fri, 02/06/2004 - 10:09
Not sure what problem you are trying to report...the config is in async mode.
If you look at "sh line" it should say that the lines are in TTY mode & the interfaces them selves are seen as "interface asyn x".
Router1#sh line
* 0 CTY - - - - - 0 0 0/0 -
33 TTY - inout - - - 0 0 0/0 -
34 TTY - inout - - - 0 0 0/0 -
35 TTY - inout - - - 0 0 0/0 -
36 TTY - inout - - - 0 0 0/0 -
Are you running into connectivity issue or any other issue?
Thanks, Mak.
makchitale Fri, 02/06/2004 - 10:00
There is nothing wrong with the config but we are looking at the wrong line numbers. This is a modular router & the line numbers/ interface numbers are based on which slot in the chassis the card is inserted (show diag will give that info)
In our case the modems are in slot 1 & 2 (thus the line numbers 33-40 & 65-72). Show line will give us the lines.
So the output for line 1-7 will correctly give the above output.
http://cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00801ca70b.shtml
sh line 33 40 or sh line 65 72 should work just fine.
Thanks, Mak.
makchitale Fri, 02/06/2004 - 10:11
Thanks, Mak.
idoje Tue, 02/10/2004 - 05:59
Mak,
thanks for your help, but when I dial into the router the call doesnot get there and I tried using the phone to call a normal line its working, from sh interface see the result below, what does spoofing mean in the sh interface result?
Keepalive not set
LCP Closed
Closed: IPCP
Last clearing of "show interface" counters 00:21:53
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 6 kilobits/sec
0 packets output, 0 bytes, 0 underruns
0 carrier transitions
my calla are not entering the modem, what could cause this?
waiting for any help
thanks
Godwin
makchitale Tue, 02/10/2004 - 17:10
This being a DDR (dial on demand) interface it will show a status of UP/UP(spoofing) without any active call on the asyn interface.
NOTE:an asyn interface is not a DDR interface by default, but adding the "dialer in-band" will make it one....this is typically required for making calls OUT. Without the dialer in-band the interface status will be down/down (w/o an active call) so basically with the DDR command we are trying to tell IOS that this interface is UP & can make a call out (with the same in down state, no call will be attempted or no route out will be validated)
Coming to the call failure:
1)Can you reverse telnet into the modem & make a ATDTxxxxxxx call out?
2)For incoming calls, deb modem / deb ppp nego will be useful.
Thanks, Mak.
e-alvarez Fri, 02/06/2004 - 18:30
Does anyone know how to stop or kill a CPU process on a 1760 router?
After configuring a "modem autoconfigure discovery" on an Asnyc line, and
removing the line, the router keeps the process running,
consuming a lot of resources. The only way I know to stop this is to
reload the router.
This is the output from the router shwoing this:
Router config:
interface Async5
description ENLACE-ASYNC
bandwidth 28
ip address 180.1.160.94 255.255.0.0
encapsulation ppp
no ip mroute-cache
dialer in-band
dialer idle-timeout 60
dialer enable-timeout 10
dialer wait-for-carrier-time 60
dialer string 018006857522
dialer watch-group 1
dialer-group 1
async default routing
priority-group 3
pulse-time 1
line aux 0
script dialer reduno
modem InOut
transport input all
stopbits 1
speed 38400
line vty 0 4
password 7 13061E010803
show outputs:
S0113MTSTAFE#sh line aux 0
* 5 AUX 38400/38400 - inout - - - 2 0 56/0 -
Ready, Carrier Dropped
Line 5, Location: "ENLACE-ASYNC", Type: ""
Length: 24 lines, Width: 80 columns
Baud rate (TX/RX) is 38400/38400, no parity, 1 stopbits, 8 databits
Status: Ready, Active, No Exit Banner, Rcvd BREAK, CTS Raised
Modem Configuring, Autoconfig Running
Capabilities: Hardware Flowcontrol In, Hardware Flowcontrol Out
Modem Callout, Modem RI is CD, Line is permanent async interface
Modem state: Ready, Carrier Dropped
Modem hardware state: CTS* noDSR DTR RTS
TTY NUMBER 5
Parity Error = 0 Framing Error = 4806 Receive Error = 4807 Overrun = 56
Outcount = 0 totalout = 2249 incount = 108 totalin = 22676
Special Chars: Escape Hold Stop Start Disconnect Activation
^^x none - - none
Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch
00:10:00 never none not set
Idle Session Disconnect Warning
never
Login-sequence User Response
00:00:30
Autoselect Initial Wait
not set
Modem type is unknown.
Session limit is not set.
Time since activation: never
Editing is enabled.
History is enabled, history size is 10.
DNS resolution in show commands is enabled
Full user help is disabled
Allowed input transports are pad udptn telnet rlogin.
Allowed output transports are pad telnet rlogin.
Preferred transport is telnet.
No output characters are padded
No special data dispatching characters
S0113MTSTAFE#sh proc cpu
CPU utilization for five seconds: 25%/0%; one minute: 23%; five minutes: 21%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
81 913259913282105538 27 22.52% 22.61% 20.00% 5 Modem Autoconfig
I have tried, clearing the line aux, disconnecting the modem, resetting the modem,
clearing the dialer and none of these things has worked so far.
Even though reloading the router clears the problem, it is time consuming since the
reloading has to be done late at night, so I would like to just kill the stuck process.
I have searched Cisco website and the Internet on how to do this, but have not found
the answer yet.
Any help will be greatly appreciated.
Eduardo.
makchitale Mon, 02/09/2004 - 14:24
This surely is a bug. What IOS image are you running on the c1760?
CSCds47583 "Modem Autoconfig process stuck and using 2% CPU"
Unfortunately there is no way to kill the process thru CLI, try upgrading the IOS or open a TAC case for early resolution.
Thanks, Mak.
agis.lan21 Mon, 02/09/2004 - 04:12
Problem: simultaneous connection setup
R1(7120)-|SW|--R3(5300)--(ISDN )------- 600x
:::::::::::::::::::|35|::::::::::::::::::::::( 6xPRI )-------- Telecommuters
R2(7120)-|12|---R4(5300)--(same MSN)--- with Cisco803
:::::::::::::::::::(NetA)::::::::::::::::::(NetB=ClientBRI)::(NetC=Client-LAN)
_____________________________________________________
R1/R2:
router ospf 1
log-adjacency-changes
summary-address 255.255.0.0
redistribute connected metric 1000 subnets
redistribute static metric 1000 subnets
R3/R4:
sgbp group SGBP-GROUP
sgbp member R4(R3)
sgbp ppp-forward
sgbp dial-bids
isdn switch-type primary-net5
int dialerX
dialer map ip name
ip route 255.255.255.248
dialer caller
router ospf 1
router-id
redistribute connected subnets
redistribute static
network 0.0.0.255 area 0
IOS (tm) 5300 Software (C5300-IS-M), Version 12.2(12a)
IOS (tm) EGR Software (C7100-IK9S-M), Version 12.2(21a)
IOS (tm) C800 Software (C800-Y6-MW), Version 12.1(9)
R3 - HSRP -activ, R4 - HSRP -standby
R3+R4 -SGBP member
We have a problem with our Telecommuters which dial-in, using ISDN BRI-line.
If they come in at R4(standby HSRP), R3 establishes a second (outbound) connection within 2-5 seconds.
Any hints and tricks are welcome!
Thanks, Alex
makchitale Tue, 02/10/2004 - 17:12
Sorry Alex, I could not figure out how the setup is...if you could explain the same it will help.
Thanks, Mak.
makchitale Wed, 02/11/2004 - 17:24
Looking at the topology sketch here is what I understand:
1)When a remote 803 calls in to say R4 & connects, the R4 will have a host route (let's assume that the 803 comes with static ip address 1.1.1.1) in the routing table (1.1.1.1/32).
OSPF is supposed to distribute this as an routing update to the remaining routers.
2) In R3, show ip route 1.1.1.1 will show it's learnt via R4 as next hop with an admin value 110.....but in fact when R3 needs to send a packet to 1.1.1.1 it will see the static route with lower admin dist & actually make a call OUT.
Try increasing the admin distance on the static route on the R3:
no ip route 255.255.255.248
ip route 255.255.255.248 200 <===add 200 at the end
Now the point arises is that why did the other routers send packet destined for 1.1.1.1 to R3 instead of R4 (since they should have learnt that thru ospf). It will be interesting to see what the "sh ip route" shows on the remaining routers. Surely SGBP should not cause it, not sure if HSRP is causing it.
Please let me know if increasing the admin value fixes it....
Thanks, Mak.
cusao Thu, 02/12/2004 - 01:41
Hi, My network is a hub and spoke arrangement with some servers at the hubs so it is necessary to sometimes route spoke-hub-spoke. Main connection is T1 to all spokes and working fine. I'm trying to put in ISDN as backup and extra bandwidth. Seems easy enough with backup interface and threshold commands but I'm guessing it is a bad idea to configure these at both ends of the link? yet if at spoke only how does hub know to reserve BRI as backup only. I have EIGRP marked as uninteresting but concerned that ISDN will dial needlesly.
makchitale Thu, 02/12/2004 - 12:39
With the backup command configured & the primary link still up the DDR interface will be in standby mode, until & unless router sees line protocol go to down state it will not change to UP/UP(spoofing). In case of a T1 it will not really matter of you have the backup command on either end since the p2p DOWN T1 will get the DDR interfaces out of the standby mode.
Thanks, Mak.
cusao Fri, 02/13/2004 - 01:37
Thanks Mak, I understand how the DDR will come out of standby if the T1 is down but do the routers communicate about standby status? If not my concern remains that the end without the backup interface command will attempt to use the DDR when T1 is up unless I command it not to. The same question then applies to the backup load command. Do I actually cause a problem by configuring both ends?
best regards
makchitale Fri, 02/13/2004 - 09:44
You have a valid concern when using both the backup interface & backup load commands under the T1 interface, I will trying out the same in my lab to see if the load itself brings the DDR interface out of the standby mode (you can ping me off-line at [email protected]).
The end without the backup command will not use the DDR interface if we have the interesting traffic correctly defined....NOTE: when using the backup method (backup command or floating static or dialer watch) a careful evaluation needs to be made of which best suits your environment & requirements. Please refer the below URL for the same:
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_tech_note09186a008009457d.shtml
Thanks, Mak.
makchitale Fri, 02/13/2004 - 10:14
Thanks, Mak.
michael.wilkerson Fri, 02/13/2004 - 07:22
I am using a 3640 for dial-up connectivity for my RAS. Question I have is when I set of the local IP pool for the interfaces, is there a way to force the IPs to go in order instead of first available. I would like to start at the first IP assigned and toggle through all in the range before coming back to the first. The command I have in at this point is:
ip local pool dialup xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx.
Is there something that gets added to this command to force IP selceltion in sequence?
makchitale Fri, 02/13/2004 - 10:18
Assigning the first IP address & going thru the complete range before going back to the first is the default behaviour..I just tried out the same & see it happen. I tried with 12.2 mainline image, what image are you running on the 3640? Can you try playing around with the cache-size at the end of the local pool command to see if that works.
Thanks,Mak.
michael.wilkerson Fri, 02/13/2004 - 11:47
I am currently running 11.3T(10)
Here are the pertinent commands for the dialup pool:
ip unnumbered Ethernet3/0
no ip directed-broadcast
encapsulation ppp
peer default ip address pool dialup
no cdp enable
group-range 33 56
encapsulation ppp
no cdp enable
group-range 65 88
ip local pool dialup 131.15.160.50 131.15.160.120
Is the cache size a feature with a different IOS?
dmillsom Fri, 02/13/2004 - 08:15
I am having problems getting the AUS port on my 3640 to talk ppp. I have a Hayes Accura v.92 modem
connected.
If I dial up the line using hyperterm I get a username prompt and can log in successfully.
If I enter ppp it says ppp is not permitted on this line.
Here is some of the conficuration:
line aux 0
exec-timeout 0 0
modem InOut
exec prompt timestamp
transport preferred lat pad v120 lapb-ta mop telnet rlogin udptn nasi ssh
autoselect arap
speed 57600
pagemill#sho running in async129
Building configuration...
Current configuration : 276 bytes
interface Async129
description AUX
ip unnumbered Loopback3
encapsulation ppp
ip tcp header-compression
autodetect encapsulation ppp lapb-ta
peer ip address forced
no keepalive
ppp authentication chap ms-chap ms-chap-v2 pap
end
makchitale Fri, 02/13/2004 - 10:22
Please try the following:
conf t
int a129
line aux 0
autoselect ppp
Thanks, Mak.
rhegde Fri, 02/13/2004 - 09:47
I have AS5350 . How do I fix the modem speed to 9600 bps on group of 20 digital modems ?
