Unity server with 2 nics and ip addresses
Feb 2nd, 2004
I want to know if Unity 4.0(2) supports two nics with different ip addresses. It currently has both active, but when i check the VM ports on the Call Manager, Unity has registered into CCM with the IP Address of the second NIC, which is non-routable. It actually sits on the same VLAN as the CCM using NIC1. Can i change the source address??
eschulz Mon, 02/02/2004 - 21:01
  • Cisco Employee,
The "Configuring Dual NICs in the Cisco Unity Server" section in the Installation guide should answer your question. Here's the link for 4.0(2)...
www.cisco.com/en/US/products/sw/voicesw/ps2237/products_installation_guide_chapter09186a00801507e9.html#1592700
Basically, you have three options...
1. Run a fault tolerant mode
2. Disable TCP/IP for the second NIC
3. Disable the second NIC in the BIOS
