Warning message
Help Needed DDR on second call Number
Feb 3rd, 2004
Hi Ciscoer,
Here's the config of current router dial to main site,
interface f0/0
ip add 192.168.13.254 255.255.255.0
int s0/0
backup delay 1 120
backup interface dialer1
ip address 192.168.253.9 255.255.255.0
encap frame-relay
frame-relay map ip 192.168.253.1 80 broadcast
interface BRI0/0
encap ppp
dialer rotary-group 1
isdn switch0type basic-net3
int async65
encap ppp
dialer in-band
dialer rotary-group 2
async mode dedicated
int dialer1
ip add 192.168.252.6 255.255.255.252
encap ppp
dialer in-band
dialer map snapshot 1 name MainRouter broadcast 1111111
dialer map ip 192.168.252.5 name MainRouter broadcast 1111111
dialer hold-queue 10
dialer load-threshole 10 outbound
dialer-group 1
snapshot client 15 360 suppress-statechane-update dialer
ppp authentication chap
ppp multilink
int dialer2
ip address 192.168.251.6 255.255.255.252
encap ppp
dialer in-band
dialer map snapshot 1 name SecondRouter modem-script broadcast 2222222
dialer map ip 192.168.251.5 name SecondRouter modem-script default broadcast 2222222
dialer-group 1
snapshot client 5 360 suppress-statechange-update dialer
router igrp 1
net 192.168.13.0
net 192.168.251.0
net 192.168.252.0
net 192.168.253.0
ip route 192.168.10.0 255.255.255.0 192.168.252.5 150
ip route 192.168.10.0 255.255.255.0 192.168.253.5 200
access-list 101 deny igrp any any
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
Questions:
1. Can I have the dialer2 dial to diffrent phone no and diffrent subnet using "dialer map" (So I have other RAS server located to backup site-192.168.12.0)
2. If so, the ip route 192.168.12.0 255.255.255.0 192.168.251.5 201; will the command be interesting to place the second call?
So, my setup will Frame-relay, ISDN, DIAL #1, DIAL #2
Thank's in Advanced,
Best Regards,
HATO
vcjones Wed, 02/04/2004 - 05:57
  • Silver, 250 points or more
Q1. Can I have the dialer2 dial to diffrent phone no and diffrent subnet using "dialer map" (So I have other RAS server located to backup site-192.168.12.0)
A1. Yes, but... You also will need a mechanism that will detect when the alternate dialer is required. This is not supported by standard Cisco configurations, but can be done with a little trickery.
Q2. If so, the ip route 192.168.12.0 255.255.255.0 192.168.251.5 201; will the command be interesting to place the second call?
A2. No. As far as the 2nd dialer is concerned, the first dialer is always available (it will either be up or up(spoofing)).
Q3. So, my setup will Frame-relay, ISDN, DIAL #1, DIAL #2
A3. You can do this, but you'll need to start over using either dialer watch or BGP driven DDR to do the job. This also requires using an easily filtered routing protocol such as EIGRP or RIPv2 between the two sites so the calling router can detect which links are up and available.
See the white paper "Using BGP to Trigger Multiple Levels of Dial Backup on Cisco Routers" on my web site (or Chapter 5 - "Advanced Dial Backup" of my book High Availability Networking with Cisco) for more on the techniques required to do the job.
Good luck and have fun!
Vincent C Jones
www.networkingunlimited.com
