Slow Convergence
Feb 4th, 2004
I have a hub and spoke network. My hub consists of 2 routers. The primary router connects to spokes via ISP MPLS VPN (CE is running BGP with PE) while the ISDN router served as backup, connects to spokes via 128k ISDN (floating static route method). We are using PRI at hub and BRI at spokes.
My IGP is EIGRP. BGP at primary router and static route at ISDN router are redistributed into EIGRP.
When the primary line is failed, the ISDN kick in successfully but the floating static route never appear in the hub's ISDN router routing table. External EIGRP route which indicates the best path to spokes is via primary router still appear in the ISDN router routing table, causing traffic cannot flow from hub to spokes via ISDN line. The external EIGRP route finally replaced by the floating static route after 2 minutes and 15 second. In other words, my WAN network take 2 minutes and 15 second to converge. 2minutes++ seems too long for me. How to reduce the convergence time significantly?
PRIMARY ROUTER CONFIG
C1#sh ru
Building configuration...
Current configuration : 2655 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname C1
ip subnet-zero
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 202.163.53.214 255.255.255.252
duplex auto
speed auto
router eigrp 1
redistribute bgp 65001 metric 10000 100 255 1 1500
redistribute connected
network 192.168.1.0
no auto-summary
router bgp 65001
bgp log-neighbor-changes
network 0.0.0.0
neighbor 202.163.53.213 remote-as 9255
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip http server
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
ISDN ROUTER CONFIG
C2#sh ru
version 12.1
hostname C2
controller E1 1/1
pri-group timeslots 1-31
username S1 password 0 abc
ip subnet-zero
isdn switch-type primary-net5
ip address 192.168.1.3 255.255.255.0
duplex auto
speed auto
interface Serial1/1:15
no ip address
encapsulation ppp
ppp authentication chap
ppp multilink
dialer pool-member 1
interface dialer0
ip address 172.16.1.1 255.255.255.252
encapsulation ppp
dialer idle-timeout 300
dialer remote-name S1
dialer string 12345678
dialer load-threshold 125 either
dialer-group 1
dialer pool 1
ppp multilink
router eigrp 1
redistribute static metric 128 2000 255 1 1500
distribute-list 1 out static
network 192.168.1.0
no auto-summary
ip classless
ip route 192.168.2.0 255.255.255.0 172.16.1.2 250
no ip http server
access-list 1 deny 0.0.0.0
access-list 1 permit any
dialer-list 1 protocol ip permit
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
SPOKE ROUTER CONFIG
S1#sh ru
version 12.1
hostname S1
username C2 password 0 abc
ip subnet-zero
isdn switch-type basic-net3
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
interface BRI0/0
ip address 172.16.1.2 255.255.255.252
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer map ip 172.16.1.1 name C2 87654321
dialer-group 1
ppp multilink
ip address 172.22.31.165 255.255.255.252
duplex auto
speed auto
router bgp 65002
network 192.168.2.0 mask 255.255.255.0
neighbor 202.163.53.217 remote-as 9255
neighbor 202.163.53.217 ebgp-multihop 2
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.1.1 250
ip route 202.163.53.217 255.255.255.255 172.22.31.166
no ip http server
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
Average Rating: 5 (1 ratings)
aretana Wed, 02/04/2004 - 13:15
Hi!
You are describing the case in which the physical link between the spoke and the provider fails...correct?? That's why the ISDN link comes up: the spoke detects it, eliminates the BGP-learned route and the floating static kicks in.
On the other hand, the Hub ISDN router has to wait for the routing to be updated through a longer path:
- the provider has to detect the failure in the local link (only this step is the same as the spoke)
- BGP in the provider's network has to propagate the routing change internally
- BGP has to propagate the change to the Hub CE
- BGP takes the route off the routing table
- EIGRP notices the change and removes the route from the network
- the floating static route kicks in the Hub ISDN router...
There are several steps that can contribute to the time you're seeing, but not everything is lost. IMHO, you may be able to reduce the 2+ minutes with some tunning. However, you really only have control over the part of the proces that happens in your network:
Once BGP receives the route withdraw, it take the route off the routing table right away... Likewise, EIGRP takes that information and pruges it immediatelly...and the static route kicks in right away. In other words, the process inside your network is negligible. The only thing that could be slowing you down internally is EIGRP's query process...but, assuming that there's no other route to the remote subnet, then this too should be pretty much nothing.
I ran a quick debug in the lab to make sure I'm telling the truth. :-) This is the equivalent of your Hub BGP router when the route is withdrawn:
Feb 4 19:51:02.320: BGP(0): 140.1.100.2 rcv UPDATE about 10.1.0.0/16 -- withdrawn
Feb 4 19:51:02.320: BGP(0): no valid path for 10.1.0.0/16
Feb 4 19:51:02.320: BGP(0): nettable_walker 10.1.0.0/16 no best path
Feb 4 19:51:02.320: RT: del 10.1.0.0/16 via 140.1.100.2, bgp metric [20/0]
Feb 4 19:51:02.320: RT: delete subnet route to 10.1.0.0/16
Feb 4 19:51:02.336: IP-EIGRP(Default-IP-Routing-Table:5): 10.1.0.0/16 - not in IP routing table
Feb 4 19:51:02.336: IP-EIGRP(Default-IP-Routing-Table:5): Ext 10.1.0.0/16 metric 4294967295 - 0 4294967295
Feb 4 19:51:02.352: IP-EIGRP(Default-IP-Routing-Table:5): Processing incoming REPLY packet
Feb 4 19:51:02.352: IP-EIGRP(Default-IP-Routing-Table:5): ExtS 10.1.0.0/16 M 4294967295 - 1249792 4294967295 SM 4294967295 - 1249792 4294967295
It takes it about 100ms...
Now this is the equivalent to your ISDN Hub:
Feb 4 19:51:02: IP-EIGRP(Default-IP-Routing-Table:5): Processing incoming QUERY packet
Feb 4 19:51:02: IP-EIGRP(Default-IP-Routing-Table:5): Ext 10.1.0.0/16 M 4294967295 - 0 4294967295 SM 4294967295 - 0 4294967295
Feb 4 19:51:02: RT: delete route to 10.1.0.0 via 140.1.10.49, eigrp metric [170/1787392]
Feb 4 19:51:02: RT: no routes to 10.1.0.0
By now you should know that the bulk of the time is being spent at the provider's network. Back to your original question: "How to reduce the convergence time significantly?". Go talk to your service provider. Show them the time difference between a link going down at a spoke and the BGP update being received at the Hub. There are some things they can change in the configs to help you out...
Good luck!
Alvaro.
lehpoh Thu, 02/05/2004 - 10:28
Thanks for your prompt reply, I will go and talk to my ISP.
Login or Register to take actions
Posted February 4, 2004 at 8:32 AM
Stats:
Replies:2 Avg. Rating:5
Views:222 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
Rank Username Points
1 2,069
2 1,732
3 1,675
4 1,624
5 1,529
