Configuration
Feb 5th, 2004
Can anybody please help me config a 2600 series router to work in my network. If you have cisco configmaker look at this diagram, if not then read on. I have one router, a 3Com switch, 6 servers and 25 workstations in the network. I'm using a class C address 192.168.123.0. How will i config the router to work for me.
Georg Pauwen Thu, 02/05/2004 - 12:04
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
what are you trying to achieve ? Do you need your router to talk to another site ?
Basically, you need one switchport for each workstation and server. Assign an IP address from your class C range to each workstation and server. Assign an IP address from the range to the (Fast)Ethernet interface of your 2600, this usually is the first usable address, 192.168.123.1/24 in your case. This address is also the default gateway for all your workstations and your servers.
For the remainder, you need to provide more info on what you are trying to do with your router.
HTH,
Georg
baileja Thu, 02/05/2004 - 17:30
eokai,
Your setup seems very easy. It appears that you have no internet connection, is that the case? The following is all you should need.
hostname lab
interface fastethernet0/0
ip address 192.168.123.1 255.255.255.0
no shut
For what your asking, the config above is the only thing you need. In fact, from looking at your map, you dont even need a router. You only have one subnet and no internet connection. The router will never route anything in this scenario. Is there more to the diagram than you have posted?
oldman Fri, 02/06/2004 - 05:26
HI
agree with GPAUWEN
you must give us more information
what do you want your router to do for you
just for communication bewteen vlans ?or connect to other routers?
