Warning message
PA and CallManager integration
Feb 6th, 2004
We have an existing PA server which was originally homed to a CallManager 3.1(2)c cluster. We installed a new CallManager 3.3(3)sr4 and we rehomed the PA Server to the new CallManager 3.3(3) cluster but cannot get things working
I have upgraded JTAP, all ports for PA in CM are registered and all changes made in PA admin page to point to new CM cluster. The route points for PA in CM are not registering although they are all associated with PA user. I dissasociated and reassociated them with no success. I have also rebooted PA several times. Any ideas??
trailman73 Fri, 02/06/2004 - 09:52
  • Bronze, 100 points or more
Do you have your ODBC pointing to the correct server, did you change the ip of ccm?
Geoff
n.kyei Fri, 02/06/2004 - 11:55
Yes I did change the ip of the CCM but I will go and check into the ODBC connection. I will let you know what happens.
