Warning message
Serial interface dont appears in my config
Feb 7th, 2004
I have two routers cisco1721 using IOS with IPSEC 3DES features. But, When i Check my serial interface, it dont apears in my config so i have WIC-1T card inteface.
What is the problem. The two routers are new.
Plz I need Help,
Overall Rating: 3 (1 ratings)
baileja Sun, 02/08/2004 - 00:18
You do not have the correct IOS to support the WIC-1T. What image do you currently have, I can give you the name of the one you need if you give me the version you have and what your needs are.
lincolnp1 Mon, 02/09/2004 - 00:09
I've also noticed when you have configured virtual templates (used mainly for async routing) associated with serial int's, you do not see the serial configuration when a 'sh run' cmd is executed ...
kheireddine.seb... Mon, 02/09/2004 - 10:06
hello,
alwyas the same problem. I attached a sh tech of my router plz check it and give me a feedback.
you will find all the information you need.
Best regards
Kheireddine
baileja Mon, 02/09/2004 - 12:19
As I said before, your IOS. You must download a different version.
tblancha Mon, 02/09/2004 - 10:52
  • Cisco Employee,
For the 1721, the wic-1t is not supported in mainline 12.2 code but is in 12.2T. As per the HW/SW matrix, these are the minimum supported IOS levels for the wic-1t and 1721.
12.2(4)YA, 12.2(4)YB, 12.2(4)YH, 12.2(8)T, 12.2(8)YJ, 12.2(8)YL, 12.2(8)YM, 12.2(8)YN, 12.2(11)T, 12.2(11)YU, 12.2(11)YV, 12.2(13)T, 12.3(1)
kheireddine.seb... Tue, 02/10/2004 - 03:06
Hello all,
Thanks for your help, now i use c1700-y-mz.122-4.YA2 IOS, i can see the serials (WIC-1T) but dont supprot IPSEC.
Now, i would use IPSEC 3DES in my router so it has only 32 mB Ram and 16 MB Flash.
Wich Release can i use in this case.
Plz Help me.
Kheireddine
kheireddine.seb... Wed, 02/11/2004 - 02:31
Hello all,
My router has only 32Mb Ram and 16 Mb Flash.
Is there Release suppports IPSEC 3DES to use with my router.
Urgent
Best regards
Kheireddine
bbranch Thu, 02/12/2004 - 00:44
  • Silver, 250 points or more
Unfortunatley you need a minimum of 48Mb of DRAM for all 1721 IPSec images that support the WIC-1T:
12.2T
File name Min. Memory(MB) Min. Flash(MB)
c1700-k9sy7-mz.122-15.T11.bin 48 16
12.2YA
c1700-k9sy7-mz.122-4.YA6.bin 48 16
12.3
c1700-advsecurityk9-mz.123-5b.bin 48 16
kheireddine.seb... Sat, 02/14/2004 - 01:35
Hello all,
I thank all for your helps.
Now, i must upgrade my routers to 48Mb Ram.
Best regards
Kheireddine
