dedicated bandwith to MPLS VPN customer
I need to configure 2 PE router that is customer's locations connected to give customer dedicated bandwidth. there is 1 P router between PE routers. So what kind of configuration I can make to give one vpn customer to dedicated BW. I looked for MPLS DS-TE config but I couldn't find implementation about VPN side with MPLS DS-TE.
regards,
Gurkan
waris Tue, 02/10/2004 - 03:54
  • Cisco Employee,
DS-TE will gurantee bandwidth in the core network.
It won't do what you are looking for.
P router has no knowledge of customer network.Its just switching the mpls packets.
Which kind of media you are using ATM,Gig or POS ?
How many customers are connected to each PE router ?
