set ip next-hop verify-availability
Feb 11th, 2004
Apologies for the rather long message!
If I enable "set ip next-hop verify-availability", my policy routing fails (i.e. normal def. gw of router is taken):
interface Port-channel1.121
encapsulation dot1Q 121
ip address 203.149.69.49 255.255.255.252
ip policy route-map unlimited-traffic-test
route-map unlimited-traffic-test permit 10
match ip address 105
set ip next-hop 203.149.66.198
access-list 105 remark ACL for Policy Routing to force certain subnets via Open-pipe and redundant secondary
access-list 105 deny ip any 203.149.64.0 0.0.15.255
access-list 105 deny ip any 203.63.239.0 0.0.0.255
access-list 105 deny ip any 210.10.54.0 0.0.0.255
access-list 105 deny ip any 210.10.55.0 0.0.0.255
access-list 105 permit ip 203.149.69.48 0.0.0.3 any
Feb 12 14:26:15.573 aest: IP: s=203.149.69.50 (Port-channel1.121), d=203.94.129.130, len 38, FIB policy match
Feb 12 14:26:15.573 aest: IP: s=203.149.69.50 (Port-channel1.121), d=203.94.129.130, len 38, FIB policy rejected - normal forwarding
Feb 12 14:26:15.581 aest: IP: s=203.149.69.50 (Port-channel1.121), d=203.94.129.130, len 38, FIB policy match
Feb 12 14:26:15.581 aest: IP: s=203.149.69.50 (Port-channel1.121), d=203.94.129.130, len 38, FIB policy rejected - normal forwarding
If I remove set ip next-hop verify-availability, then the policy-routing is honoured.
I have "ip cef" enabled on both routers.
My ideal scenario is to have a "primary" def gw for certain subnets, and in the event of that gw becoming unavailable, a secondary gw is taken -
set ip next-hop 203.149.66.198 203.63.121.150
But if the first IP in next-hop is down, traffic goes no-where - Hence the reason I believe I need "set ip next-hop verify-availability" working?
Thanks in advance.
MB
saimbt Wed, 02/11/2004 - 21:12
Hi MB,
The command "set ip next-hop verify-availability" works on Cisco Discovery Protocol (CDP), please enable CDP on the router, this might do the trick..
Cheers,
Sai.
mbellears2 Wed, 02/11/2004 - 21:28
Can confirm that cdp is already enabled on both routers.
MB
saimbt Wed, 02/11/2004 - 23:38
Hi MB,
This command first appeared in Cisco IOS Release 12.0(3)T.
Can you check the IOS version of the routers that you are using??? (I am assuming that your IOS supports this command)..
-Sai.
mbellears2 Thu, 02/12/2004 - 13:38
Certainly -
Router 1 (7206VXR):
>sh ver
IOS (tm) 7200 Software (C7200-IS-M), Version 12.1(5)T6, RELEASE SOFTWARE (fc1)
Router 2 (2651):
>sh ver
IOS (tm) C2600 Software (C2600-IK8O3S-M), Version 12.2(19a), RELEASE SOFTWARE (fc2)
MB
mbellears2 Thu, 02/12/2004 - 19:31
Looks Excellent - My only issue is that my remote router is 'remote'! - I would have to fly there to upgrade the IOS.
Has anyone succeeded in using set ip next-hop verify-availability?
MB
