Warning message
PIX 525 losing running-config
Feb 12th, 2004
I have a pair of PIX 525 set for failover. Since upgrading to 6.3(3), we have been having periodic failures in that the active device loses its running config, it transfers the default config to the standby. The proper config remains in flash and a reboot corrects problem. TAC has not been much help on this. This problem is erratic. Sometimes goes several days without a problem, sometimes a few hours.
nkhawaja Fri, 02/13/2004 - 14:11
  • Cisco Employee,
Is there any SYSLOG message you recorded? it seems to be some bug and TAC's help is advisable here.
Has the failover happening?
Nadeem
rmerritt Mon, 02/16/2004 - 04:58
Syslog does not show a thing. Device does not fail over but does write the default settings to the secondary. I am not familiar with sho crash. I will look at that the next time it occurs. Thanks for your assistance.
mhoda Sat, 02/14/2004 - 23:45
  • Silver, 250 points or more
How did you verify that it looses it's running config? It can be because of number of reasons why FO is occuring. What does syslog shows? do you have show crash? these are the things you need to look at and search for possible bug.
Mynul
