Warning message
IPCC Monitoring via Dual-NIC
Feb 12th, 2004
Hi.. I am running CRA 3.1(2) sr3 and would like to setup VoIP Monitoring via the Dual NIC configuration. CCO has a document that states I have to play with the Registry in order to change settings for Monitoring via the second NIC.. Is this true? If so, how accurate is the documentation?
Also, if someone can point me in the direction of better VoIP Monitoring documentation, I'd appreciate it.
Lee
yogeswar Thu, 02/12/2004 - 21:31
  • Silver, 250 points or more
Here is how to change the registry entry to use the second NIC card.
I have used my servers Hardware Address as a example, replace it with yours
Get the Hardware Address for the Second NIC Card from:
HKEY_LOCAL_MACHINE->SOFTWARE->Microsoft->Windows
NT->CurrentVersion->NetworkCards->2->ServiceName
Mine is = {C96E85FA-7214-4D71-8B9F-19B7C97F44F5}
Set HKEY_LOCAL_MACHINE->SOFTWARE->Spanlink->FastCall VoIP Monitor
Server->Setup->MONTITOR DEVICE
to \Device\Packet_{C96E85FA-7214-4D71-8B9F-19B7C97F44F5}
For CRS 3.1(1)and above its \Device\Splkpc_{C96E85FA-7214-4D71-8B9F-19B7C97F44F5}
After making the change restart the following two services in the order listed:
Cisco Desktop VoIP Monitor Server.
Cisco Desktop RASCAL Monitor server.
You will need to close and then re-open your Supervisor & Agent Desktops after restarting the services.
Check out the following URL for VOIP monitor settings.
http://www.cisco.com/en/US/products/sw/custcosw/ps1001/products_tech_note09186a008010e6ba.shtml
Check out the following URL for setting up dedicated VOIP server.
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/apps_3_1/english/admn_app/get_str/gsappa_1.htm
Also have a look at the following URL
http://www.cisco.com/univercd/cc/td/doc/product/voice/ics/icsapps/icscra/cra30/icsspan.htm
Yogi
frazier24 Mon, 02/16/2004 - 15:20
Thanks Yogi.. I got desperate, so I opened a TAC Case, and the SE there helped me with the exact Reg edits I needed (the same as you provided above).
It amazed me that the CCO info was not as accurate as what TAC and you provided. I wish they'd update the CCO info real soon so that others can use this information.
Lee
