Warning message
webVPN
I am testing the webVPN with a VPN 3030 box and MS IE 6.0. Everything looks good, until I try to browse to an HTTPS website. For instance, I am at keybank.com, trying to go to the login page, which is an https page. Get an error" server may not exist or access not allowed".
I have allowed everything right now, so it should let me go to any website, right?
Any ideas?
myron.coulson Mon, 02/16/2004 - 16:05
Did you generate the certificate for the concentrator. Under Managment, certificates, I think.
myron.coulson Tue, 03/02/2004 - 05:10
I can get to HTTPS sites it's just some java based applications that don't work through web vpn. pix pdm, switch gui interface, and wlse interface all do not work through web vpn. I got https to working by re-generating the certificate on the concentrator.
According to Cisco, some Java based applications will not work.
