Unable to forward into voicemail (with more detail)
Running Unity 2.4.6.161 with a Centrex system. We used to be able to forward a caller directly into voicemail by placing the caller on hold, then dialing Unity (which takes you to sign-in), then pressing * (which used to take you to opening greeting), then entering the extension and hanging (which effectively takes the caller directly to the voicemail). Since re-installing Unity (due to a baaaad experience with ADC) we have lost this ability. Now when we call Unity it asks for password, when you hit *, it asks for your ID. If you hit it a third time, it hangs up. Transfer is set up to go directly to the greeting. Any ideas how to get this back? I don't see "Sign-in" listed under the call handlers, so how do I change the * to go to the opening greeting?
lindborg Thu, 02/12/2004 - 13:48
  • Cisco Employee,
You asked this question on another thread and I responded a few days ago - not sure if you're looking for a better answer or didn't want to continue that thread or what...
There's a couple of ways to handle this - short story I believe you can hit "#" when it asks for the ID and that takes you to the subscriber sign in - that changed along the way (I didn't think till 3.x).
You have a number of other ways to handle this - here's links to a few tech tips that discuss your options:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a00800dea82.shtml
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps2237/products_tech_note09186a008015b963.shtml
