vwic with AIM card
Feb 12th, 2004
I have VWic-1MFT-T1 installed in WIC 0 slot as well as AIM-voice-30 installed on the motherboard of 2611XM router. What is the config for AIM to work so the T1 can start using those DSP resources. Also the network-clock-participate wic0 is the referring to AIM or Vwic-MFT-T1?
This is what i have so far:
network-clock-participate wic 0
network-clock-select 1 T1 0/0
gregg.davis Thu, 02/12/2004 - 20:57
network-clock-participate aim 0 (slot#)
tdhaliwal Fri, 02/13/2004 - 11:05
Thanks for the response. I'm not able to see the second command with aim 0. Only option i have is wic or slot#. I'm running 12.2.15zj3 code. Please let me know what i'm missing.
pacameron Sat, 02/14/2004 - 05:11
  • Silver, 250 points or more
The 2600 doesn't have the keyword as there is only one AIM slot so it is implicit that it is to be used as a DSP resource. You do need the keyword as there are multiple WIC slots. Make sure you also add the network-clock-select t1 0/0 keyword as well.
tdhaliwal Sat, 02/14/2004 - 08:53
Thanks. So all i need is network-select-clock t1 0/0 to make this work.
