Warning message
vpn3000 (v4.1) : WebVPN & Radius (IAS)
Feb 13th, 2004
I've create a group to apply some specifics port redirections.
It working fine with internal users & nt domain!
But when I use a radius server (IAS) for authentification, the port
redirection is not apply ?
Is somebody have the same problem ??
Damien
HEATH FREEL Fri, 02/13/2004 - 06:00
To use RADIUS within groups for WebVPN you must set an aditional Attribute in the RADIUS Server.
Assigning WebVPN Users to Groups
Using a RADIUS server to authenticate users, assign users to groups by following these steps:
Step 1 Authenticate the user with RADIUS and use the Class attribute to assign that user to a particular group.
Step 2 Set the class attribute to the group name in the format OU=group_name
For example, to set a WebVPN user to the SSL_VPN group, set the Radius Class Attribute to a value of OU=SSL_VPN; (Don't omit the semicolon.)
hwrt Fri, 02/13/2004 - 06:35
it resolve my issue !
Damien
