Warning message
queuing on 34 Mbit
Feb 16th, 2004
Is it possible to do queuing on 34 Mbit-links? 10 Mbit-links?
Since WFQ is only enabled per default on 2Mbit-interfaces I guess there is a buffer problem doing queuing on higher speeds? Is there a good document somewhere describing queuing on higher speeds?
I'd whish to do CBWFQ and WRED if possible...
Using 3745/3725/7206-routers.
olorunloba Mon, 02/16/2004 - 11:02
  • Silver, 250 points or more
You can do your queueing on the E3 interfaces, but the big question is the reason why you will want to do that. On slower links, the different queueing systems are used to optimise performance, but on a link like E3, often performance is not an issue. Also, because links like 34mbit are found in providers core, they will generally use fifo because this has the minimum resource requirement (in terms of cpu and memory).
frejac Mon, 02/16/2004 - 23:15
The Why?-question is easy. I dont want the most
important data to be dropped when there is
congestion. We work in the banking/finance-sector and hence some traffic is very important while others isnt. But if someone does a large file-copy if must not affect the critical systems.
So what are you saying? That it's doable or not?
ahvn Mon, 02/16/2004 - 23:31
I don't think terminating an E3 hamper your chances of implementing queing. I feel you need to configure cef anyway and no ip route-cache in your exit interfaces and then apply the needed queing commands applying the reqired logic for your need.
Rgds
Homin
frejac Tue, 02/17/2004 - 02:56
Thanks, ahvn.
Anybody know for sure?
olorunloba Tue, 02/17/2004 - 08:23
Yes for sure, it can be configured. Your office must be quite large to required you do QoS on an E3 link.
