DISL on 1900 switch
Feb 18th, 2004
I read that the 1900 switch only run Dynamic Inter-Switch Link (DISL). Does that mean that I cannot trunk between a 1900 and non cisco switch, since I would need to use 802.1q.
Does the 2820 only use DISL.
ziutek Wed, 02/18/2004 - 11:34
That's exactly what that means. And you can only trunk on the 100 MB ports. I am pretty sure that the 2820 will also only suport ISL trunking.
I htink if you want to use 1dotq trunking, you need a min. of either a 2900 XL model (the newer versions with 8 MB memory and entreprise edition software, 2912XL for example), or a Cat 2950. The Cat 2950 will onyl do idotq trunking I believe.
Good luck,
Joe
