Very high CPU utilisation on Cat6509 layer three module.
Feb 19th, 2004
I have three MSM modules in Cat6509s which occasionally reach 99% utilisation. One of these modules only sits on VLAN1 as a host (does not participate in routing - ie a spare unit) The only thing that I can think of which would cause the high utilisation is broadcast/flooded network traffic.
Although the router is only configured to process VLAN1 packets the switch has all vlans enabled on the internal trunk link to the MSM - This allows multiple packets to enter the router, even though they are not to be processed.
Our company utilises the Microsoft WLBS method of HA between application servers on one of the VLANs on the switch - this can cause up to 3,000 packets per second/25Mbps to flood into all the MSM modules (WBLS uses a nonexistant virtual destination MAC address for the HA server cluser which does not exist in the CAM tables of the switches causing all traffic to flood).
The question I have is - is this flooded traffic enough to cause problems for the router, even though the router should discard them or would there be another reason for the high CPU values. An expample of the show proc cpu is given below:
Many thanks
R hughes
Europa# sh proc cpu
CPU utilization for five seconds: 97%/76%; one minute: 86%; five minutes: 47%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 12972 2151011 6 0.00% 0.00% 0.00% 0 Load Meter
2 176 140 1257 0.24% 0.06% 0.02% 2 Virtual Exec
3 27371260 2200973 12436 0.32% 0.28% 0.33% 0 Check heaps
4 0 1 0 0.00% 0.00% 0.00% 0 Pool Manager
5 0 2 0 0.00% 0.00% 0.00% 0 Timers
6 26658632 54577884 488 0.32% 0.27% 0.23% 0 ARP Input
7 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
8 0 2 0 0.00% 0.00% 0.00% 0 DDR Timers
9 0 2 0 0.00% 0.00% 0.00% 0 Entity MIB API
10 0 1 0 0.00% 0.00% 0.00% 0 OIR Handler
11 0 2 0 0.00% 0.00% 0.00% 0 EPIF reset proce
12 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
13 15160 10751670 1 0.00% 0.00% 0.00% 0 IPC Periodic Tim
14 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat Manager
15 46696 2264921 20 0.00% 0.00% 0.00% 0 HC Counter Timer
16 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
17 504 20 25200 0.00% 0.00% 0.00% 0 EPAM Card Manage
18 8 16 500 0.00% 0.00% 0.00% 0 EPIF Enable If p
19 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
20 16804 1131178 14 0.00% 0.00% 0.00% 0 Net Background
21 4364 1184 3685 0.00% 0.01% 0.00% 0 Logger
22 25116 10751949 2 0.00% 0.00% 0.00% 0 TTY Background
23 18872 10751670 1 0.00% 0.00% 0.00% 0 Per-Second Jobs
24 99144 10751897 9 0.00% 0.02% 0.00% 0 LINE Monitor Dea
25 1166064 10751896 108 0.16% 0.05% 0.01% 0 Per VC Counter
26 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM Input
27 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM TIMER
28 2092 2161438 0 0.00% 0.00% 0.00% 0 ATM Periodic
29 0 1 0 0.00% 0.00% 0.00% 0 ATM ARP INPUT
30 21488 649549 33 0.00% 0.00% 0.00% 0 PINNACLE GMAC Pr
31 5848904 358518 16314 0.00% 0.03% 0.04% 0 THERMOSTAT monit
32 10684 10775428 0 0.00% 0.00% 0.00% 0 LSIPC Periodic T
33 20870020 239618666 87 0.57% 0.18% 0.10% 0 LSIPC RECV PROCE
34 0 2 0 0.00% 0.00% 0.00% 0 LSIPC BCAST PROC
35 10716 10751625 0 0.00% 0.00% 0.00% 0 LSS port status
36 0 1 0 0.00% 0.00% 0.00% 0 CES Line Conditi
37 73896 1896107 38 0.00% 0.00% 0.00% 0 Net Input
38 15460 2151012 7 0.00% 0.00% 0.00% 0 Compute load avg
39 2925888 179210 16326 0.00% 0.01% 0.00% 0 Per-minute Jobs
40 56304 1773591 31 0.00% 0.00% 0.00% 0 CDP Protocol
41 149317272 395768095 377 3.83% 4.79% 2.97% 0 IP Input
42 139980 1144936 122 0.00% 0.00% 0.00% 0 SCP Process
43 0 13 0 0.00% 0.00% 0.00% 0 LSS VLAN Reload
44 23362052 2682517 8709 0.24% 0.19% 0.13% 0 LSS stat L3 proc
45 193310144 26402039 7321 0.89% 1.32% 1.03% 0 LSS stat L2 proc
46 387068 185200 2090 0.00% 0.00% 0.00% 0 IP Background
47 64 4903 13 0.00% 0.00% 0.00% 0 TCP Timer
48 152 265 573 0.00% 0.00% 0.00% 0 TCP Protocols
49 0 1 0 0.00% 0.00% 0.00% 0 Probe Input
50 3660 92485 39 0.00% 0.00% 0.00% 0 RARP Input
51 1561184 1373573 1136 0.00% 0.00% 0.00% 0 BOOTP Server
52 2836 179210 15 0.00% 0.00% 0.00% 0 IP Cache Ager
53 8 168 47 0.00% 0.00% 0.00% 0 AUTOSTATE proces
54 8008 187700 42 0.00% 0.00% 0.00% 0 Adj Manager
55 0 1 0 0.00% 0.00% 0.00% 0 Resource Mgmt ba
56 0 2 0 0.00% 0.00% 0.00% 0 ATMCORE OAM Proc
57 0 2 0 0.00% 0.00% 0.00% 0 ATMCORE OAM Ping
58 0 2 0 0.00% 0.00% 0.00% 0 SSCOP Input
59 0 2 0 0.00% 0.00% 0.00% 0 SSCOP Output
60 2396 179211 13 0.00% 0.00% 0.00% 0 SSCOP Timer
61 29912 10751656 2 0.00% 0.00% 0.00% 0 ATMSIG Timer
62 0 2 0 0.00% 0.00% 0.00% 0 ATMSIG Input
63 0 2 0 0.00% 0.00% 0.00% 0 ATMSIG Output
64 0 2 0 0.00% 0.00% 0.00% 0 ATM Soft VC Time
65 0 2 0 0.00% 0.00% 0.00% 0 ATM Rerouting Ti
66 127672 1075256 118 0.00% 0.03% 0.00% 0 LSS IPX Reload P
67 0 1 0 0.00% 0.00% 0.00% 0 LSS IPX BVI Proc
68 11924324 369822234 32 0.65% 0.37% 0.21% 0 LSS TB RECV PROC
69 18838440 15607440 1207 0.32% 0.33% 0.30% 0 CEF process
70 2332608 25574943 91 1.22% 0.22% 0.05% 0 LSS IP Backgroun
71 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro
72 103532 11806850 8 0.00% 0.00% 0.00% 0 LSS IP Multicast
73 12360 10751953 1 0.00% 0.00% 0.00% 0 TTY Background
74 13400 10751672 1 0.00% 0.00% 0.00% 0 Per-Second Jobs
75 21751160 68848631 315 0.32% 0.36% 0.21% 0 Standby
76 4168 179210 23 0.00% 0.00% 0.00% 0 CEF Scanner
77 512020 62698817 8 0.49% 0.23% 0.11% 0 OSPF Hello
78 39288 179278 219 0.00% 0.00% 0.00% 0 OSPF Scanner
79 0 1 0 0.00% 0.00% 0.00% 0 SNMP Timers
80 35800 435824 82 0.00% 0.04% 0.02% 0 IP SNMP
81 0 2 0 0.00% 0.00% 0.00% 0 SNMP Traps
82 1546040 13244394 116 1.88% 1.41% 0.38% 0 OSPF Router
83 0 1 0 0.00% 0.00% 0.00% 0 DSS Process
88 385432 184851 2085 0.16% 0.01% 0.00% 0 IP-RT Background
glen.grant Thu, 02/19/2004 - 18:51
  • Purple, 4500 points or more
You might want to turn netflow on temporarily to see what is generating all the traffic , possible you may have infected hosts on network . Doubt The servers would cause any major problems we have those on our our network and they don't bother the 6509's at all though we run MSFC2 instead of the old MSM's .
