easy VPN on 1721
Feb 19th, 2004
I am trying to configure easy VPN on a Cisco 1721 with a VPN module installed. When the router boots up i get the message :
*Mar 1 00:00:24.007: %CRYPTO-4-TRANSFORM_NOT_SUPPORTED:
Transform comp-lzs is not supported with the current hardware configuration
When i take the VPN module out it works. Is there any way to configure easy VPN with the harware module installed?
gfullage Thu, 02/19/2004 - 18:41
  • Cisco Employee,
You'll have something like:
crypto ipsec transform-set myset esp-des comp-lzs
Remove the "comp-lzs" cause this is compression which is not supported by the hardware module. Compression can only be done in software which is why it works when you take the module out.
ianwarb Fri, 02/20/2004 - 03:58
I don't have the command in the config you mentioned. The only config i have is for the easy VPN as follows:
crypto ipsec client ezvpn myvpn
connect auto
group group_name key shared_key
mode network-extension
peer
plus the two interface commands, inside and outside. I have tried to upgrade to an IOS that explicitly supports LZ software comp. with hardware, but am still getting the same error message upon boot up.
