show frame-relay pvc
Feb 20th, 2004
I have next output:
2610#sh frame-relay pvc
PVC Statistics for interface Serial0/0 (Frame Relay DTE)
Active Inactive Deleted Static
Local 2 0 0 0
Switched 0 0 0 0
Unused 0 0 0 0
DLCI = 20, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0/0.2
input pkts 7362481 output pkts 7070457 in bytes 677113293
out bytes 2006600249 dropped pkts 27 in pkts dropped 0
out pkts dropped 61166 out bytes dropped 74623765
late-dropped out pkts 61166 late-dropped out bytes 74623765
in FECN pkts 2230 in BECN pkts 28 out FECN pkts 0
out BECN pkts 0 in DE pkts 3388326 out DE pkts 0
out bcast pkts 117776 out bcast bytes 6351298
pvc create time 4w6d, last time pvc status changed 4w6d
DLCI = 100, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0/0.1
input pkts 115502413 output pkts 123749859 in bytes 4240586234
out bytes 3374850265 dropped pkts 0 in pkts dropped 0
out pkts dropped 1090958 out bytes dropped 544529675
late-dropped out pkts 1090958 late-dropped out bytes 544529675
in FECN pkts 172350 in BECN pkts 0 out FECN pkts 0
out BECN pkts 0 in DE pkts 67720790 out DE pkts 0
out bcast pkts 0 out bcast bytes 0
I curious about next -in FECN pkts 172350 and in DE pkts 67720790. And for out FECN and out DE i have 0. Why it's so? And what does mean high value for in pkts?
Overall Rating: 3 (1 ratings)
tblancha Fri, 02/20/2004 - 09:19
  • Cisco Employee,
The frame-relay network and not the routers at the endpoints that sets the Discard Eligible bit on a frame and is response for the Forward Congestion Notifcation so you will only inbound.
You have gotten 67720790 frames that were sent by the other side and then, marked in transit, to be eligble for discard based upon your CIR. These 67720790 frames still made it to your side even though they legally could have been dropped.
You must be bursting above the CIR as you are getting the flow control of FECN's back from the network. If this situation is causing trouble for you, you will need to purchase a higher CIR from your telco.
