Warning message
Event Id 4238 - COM+ and IIS low memory
Feb 22nd, 2004
  • Silver, 250 points or more
Have a customer with Unity install. Windows 2000 sp 3. When this starts showing up in event log the web pages can not be accessed until IIS is reset.
I have researched this on the net and haven't found much on the cause of this and how to fix it. I have seen this occur in past on another unity server, and call manager so it's a IIS issue.
Does anyone know a fix for this? sp4?
Windows Event Log details:
Source: COM+
Event ID: 4238
Type: Warning
Category: Activation
Description:
COM+ has determined that your machine is running low on available memory. In order to ensure proper system behvavior, the activation of the component has been refused. If this problem continues add more memory or increase paging file size.
