error message in the log
I can ping the WAN serial interface, no problem. But I got this error message fill out my log. Any idea??
-Traceback= 80050734 80066B60 80026864 8002CC60 8002A860 8014C3B0 8012163C 80140
EF8 80140EF8 801216FC 8009E910 8009E8D0 80125E7C 80122908 80008120
Feb 24 15:00:42: %IPFAST-2-PAKSTICK: Corrupted pak header for Serial0, flags 0x8
EF8 80140EF8 801216FC 802068C0
Feb 24 15:01:42: %IPFAST-2-PAKSTICK: Corrupted pak header for Serial0, flags 0x8
EF8 80140EF8 801216FC 80114BB0 80125E7C 80122908 80008120
Feb 24 15:02:42: %IPFAST-2-PAKSTICK: Corrupted pak header for Serial0, flags 0x8
EF8 80140EF8 801216FC 801265FC 80125E7C 80122908 80008120
Feb 24 15:03:42: %IPFAST-2-PAKSTICK: Corrupted pak header for Serial0, flags 0x8
EF8 80140EF8 801216FC 80127608 80125E7C 80122908 80008120
Feb 24 15:04:42: %IPFAST-2-PAKSTICK: Corrupted pak header for Serial0, flags 0x8
EF8 80140EF8 801216FC 800A2E6C 802083A8 8009E8D0 80125E7C 80122908 80008120
Feb 24 15:05:42: %IPFAST-2-PAKSTICK: Corrupted pak header for Serial0, flags 0x8
Feb 24 15:06:43: %IPFAST-2-PAKSTICK: Corrupted pak header for Serial0, flags 0x8
EF8 80140EF8 801216FC 80125E84 80125E7C 80122908 80008120
Feb 24 15:07:43: %IPFAST-2-PAKSTICK: Corrupted pak header for Serial0, flags 0x8
EF8 80140EF8 801216FC 802068BC
Feb 24 15:08:43: %IPFAST-2-PAKSTICK: Corrupted pak header for Serial0, flags 0x8
EF8 80140EF8 801216FC 80206828 80204C50 80208498 80208394 8009E8BC 80125E7C
lgijssel Tue, 02/24/2004 - 01:30
  • Red, 2250 points or more
Traceback messages are generally an indication that there is a problem with the IOSimage that you are running. You can start a case with TAC and give them this info. The numbers in the message are used by the SW engineers to locate the error.
You can also try to up- or downgrade your IOS and check if the error goes away.
Leo
