Warning message
Cat6509
Feb 23rd, 2004
Hi ppl,
how does ip accounting works in MSFC? I am trying to capture what are the traffic going in and out of a busy interface vlan using the said command, but it seems like no packet were captured?
thx!
skarundi Tue, 02/24/2004 - 20:49
  • Bronze, 100 points or more
IP accounting should have little effect on a MSFC. Most traffic on a catalyst switch is routed using the supervisor's hardware, namely the Policy Feature Card.
If you want to know how much traffic is being routed through a vlan and what type of traffic it is, use Netflow Data Export.
Reference:
URL: http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_guide_chapter09186a008007fa2b.html
