Router hangs at initial configuration dialog
Feb 24th, 2004
my 2620 hangs at the initial setup:
IOS (tm) C2600 Software (C2600-I-M), Version 12.0(7)XK1, EARLY DEPLOYMENT RELEAS
E SOFTWARE (fc1)
TAC:Home:SW:IOS:Specials for info
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Wed 15-Mar-00 04:28 by phanguye
Image text-base: 0x80008088, data-base: 0x8080DBA0
cisco 2620 (MPC860) processor (revision 0x600) with 45056K/4096K bytes of memory
Processor board ID JAD05320R17 (3691429275)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:yes
I can't get into rom Mode either.
Any ideas?
Eicke
Georg Pauwen Tue, 02/24/2004 - 01:46
when you enter NO at the system configuration dialog initial configuration question, do you get a router prompt ? If so, change the configuration register to 0x2102 and reboot the router:
Router#conf t
Router(config)#config-register 0x2102
Router(config)#end
Router#wr
Router#reload
HTH,
GP
modernart Tue, 02/24/2004 - 12:06
thanks for your idea.
I finally changed to another "original" cable. And it worked.
Eicke
