Warning message
ORACLE with PIX HELP
Feb 24th, 2004
I have an oracle server running vers 8i on inside network. Have been NAT-ed and have access-list permit all the tcp and udp connection to the server when access from outside. Here the error message from client access from outside:
oracle error con 440
unable to make connection oracle - 12514 tns.couldn't resolve service name
the menu was not connectable with oracle. a menu is ended
Many Thanks for HELP
HATO
marcreiter Thu, 02/26/2004 - 12:00
Oracle 8 uses dynamic ports in its connections. While it starts on (?1531?) it negotiatats a new port about every 6-20 packets. This will result in the above msg if you do not have all ports open.
Marc
Not an expert after 20 years.
sateeshk Fri, 02/27/2004 - 17:40
hi
For testing purpose Pls try to disable NAT in firewall..and try to access the server from outside.
As per ur info u said that all ports r open diffnetly it should work.but still its not working means problem with NATTING.
Regads
Sateesh kumar.k
