Warning message
pix port forwarding
Feb 25th, 2004
I have been having a little trouble getting these few commands to take.
I need to have to inside addresses mapped to allow to sessions of pcanywhere to go through. One to the server, and one for a pc that is used by an outside company
Here is what I was trying to get to work
static (inside,outside) tcp 5633 xxx.xxx.xxx.xxx 5633 192.168.1.2 netmask 255.255.255.255 0
static (inside,outside) udp 5634 xxx.xxx.xxx.xxx 5634 192.168.1.2 netmask 255.255.255.255 0
static (inside,outside) tcp 5631 xxx.xxx.xxx.xxx 5631 192.168.1.15 netmask 255.255.255.255 0
static (inside,outside) udp 5632 xxx.xxx.xxx.xxx 5632 192.168.1.15 netmask 255.255.255.255 0
Now, when ever I try to enter these in, I get maximum number of connections should lie between 0 and 65535. I thought I specified that already
We have it working if we just want to get into the server using this
static (inside,outside) xxx.xxx.xxx.xxx 192.168.1.2 netmask 255.255.255.255 0 0
What am I doing wrong??
Any help wil be appreciated
aacole Wed, 02/25/2004 - 09:00
  • Bronze, 100 points or more
The command syntax should be:
static (inside,outside) tcp xxx.xxx.xxx.xxx 5633 192.168.1.2 5633 netmask 255.255.255.255 0 0
static (inside,outside) tcp xxx.xxx.xxx.xxx 5631 192.168.1.15 5631 netmask 255.255.255.255 0 0
So when you connect to xxx.xxx.xxx.xxx 5633 you get re-directed to 192.168.1.2 5633 and 192.168.1.15 for connections to port 5631.
Anonymous (not verified) Thu, 03/11/2004 - 12:21
Can this be done when the outside address us configured for dynamic addressing? If so can you give me the syntax.
Shawna
