DHCP Feature
d.rocco
i've got a problem with the DHCP feature on the Cisco Router:
When a PC with Windows 98 make a DHCP request, the subnet mask release by the router is 255.255.0.0
If the request is made by a PC with Windows XP or Windows 2000, I haven't got this problem (all ok).
If i do an IPCONFIG /RENEW (manually) on the PC with Windows 98, it takes the correct parametes.
You can understand that i can't say to all user with 98 to make IPCONFIG /RENEW..... ( i'll hope that when they power on the PC all is ok).
The configuration is correct.
NO DNS, NO WINS, NO PREFIX....
Only ip ,subnet and gateway.
I Repeat: The problem is only with Windows 98 PC.
I've the same problem with two different IOS.
This is the configuration
ip dhcp excluded-address 10.3.2.0 10.3.2.100
ip dhcp excluded-address 10.3.2.201 10.3.2.255
ip dhcp ping packets 3
ip dhcp pool 1
network 10.3.2.0 255.255.255.0
default-router 10.3.2.1
lease 3
In this router (1721) the release software is 12.1(1)T.
Please, give me a feedback
Thanks for the support to all.
Diego
tbruce
I use DHCP on Cisco2610 routers now and then. The only thing I don't see in your config is "no ip dhcp conflict logging" which I understand needs to be in the config. Do you have that statement in your configuration. I am using IOS 12.2(5) Have not had this issue with OS's 98,NT,2000 and XP.
