Warning message
intel centrino and access point 1100
Feb 25th, 2004
Hi i´m trying to install laptops with intel centrino processor and cisco aironet 1100, but i have no conectivity to the network, i just see associated the laptop in the access point but i can´t reach the network, i have cisco wireless lan adapter too and it works ok, just the centrino is not working, i´m using static wep and mac-authentication
but i just see this in the access point:
sh dot11 associations all-client
Address : 0004.2356.8d25 Name :
IP Address : 0.0.0.0 Interface : Dot11Radio 0
Device : - Software Version :
State : MAC-Assoc Parent : self
SSID : kerry VLAN : 0
Hops to Infra : 1 Association Id : 143
Clients Associated: 0 Repeaters associated: 0
Key Mgmt type : NONE Encryption : WEP
Current Rate : 11.0 Capability : ShortHdr
Supported Rates : 1.0 2.0 5.5 11.0
Signal Strength : -70 dBm Connected for : 319 seconds
Signal Quality : N/A Activity Timeout : 64 seconds
Power-save : On Last Activity : 65532 seconds ago
Packets Input : 132 Packets Output : 2
Bytes Input : 12992 Bytes Output : 118
Duplicates Rcvd : 0 Data Retries : 0
Decrypt Failed : 58 RTS Retries : 0
MIC Failed : 0
MIC Missing : 0
Address : 000e.84b4.58f4 Name : IRMISLAR
IP Address : 192.168.5.243 Interface : Dot11Radio 0
Device : 350-client Software Version : 5.2
Hops to Infra : 1 Association Id : 154
Key Mgmt type : NONE Encryption : WEP MIC Key-Hashing
Signal Strength : -62 dBm Connected for : 826 seconds
any ideas?
thanks
kmarrero Fri, 02/27/2004 - 05:03
  • Bronze, 100 points or more
The Centrino should work with the 1100. Try defaulting the 1100 back to factory defaults so that there is no encryption and configure the Centrino without any WEP. There is probably a configuration glitch with either the WEP or the MAC filter. With no encryption at all the two should communicate and then you can reconfigure the WEP and MAC filtering once everything works.
