NAT translation failed
NAT isn't working on a router after an IP addressing change. When I try to use NAT with nat debugging enabled, I get the following message in the logs:
NAT: translation failed (A), dropping packet s=local_ip d=remote_ip
On Cisco website, I found that "A" means the packets was dropped after routing process, but no useful information with this error message.
Configuration:
! Access-list 101 is used by NAT
! We deny packets directed to 192.168.2.0/24 through the NAT (they must go through an IPSec tunnel)
access-list 101 deny ip 192.168.3.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 101 permit ip 192.168.3.0 0.0.0.255 any
ip nat inside source list 101 interface ATM0.1 overload
interface Loopback0
ip address x.x.x.x 255.255.255.255
interface Ethernet0
ip address 192.168.3.254 255.255.255.0
ip nat inside
no cdp enable
hold-queue 100 out
interface ATM0
no ip address
no ip mroute-cache
load-interval 30
no atm ilmi-keepalive
dsl operating-mode auto
dsl power-cutback 0
hold-queue 224 in
interface ATM0.1 point-to-point
ip unnumbered Loopback0
ip nat outside
crypto map FOO
pvc 2/32
ubr 320
encapsulation aal5mux ip
additional informations:
#sh access-lists 101
Extended IP access list 101
deny ip 192.168.3.0 0.0.0.255 192.168.2.0 0.0.0.255 (30027 matches)
permit ip 192.168.3.0 0.0.0.255 any (4521 matches)
#sh ip nat statistics
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Outside interfaces:
ATM0.1
Inside interfaces:
Ethernet0
Hits: 0 Misses: 0
Expired translations: 0
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 101 interface ATM0.1 refcount 0
#sh ver
IOS (tm) C837 Software (C837-K9O3SY6-M), Version 12.2(8)YN, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Synched to technology version 12.2(11.2u)T
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 30-Oct-02 15:28 by ealyon
Image text-base: 0x800131D8, data-base: 0x8097D1E8
ROM: System Bootstrap, Version 12.2(8r)YN, RELEASE SOFTWARE (fc1)
ROM: C837 Software (C837-K9O3SY6-M), Version 12.2(8)YN, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
uptime is 1 hour, 8 minutes
System image file is "flash:c837-k9o3sy6-mz.122-8.YN.bin"
CISCO C837 (MPC857DSL) processor (revision 0x200) with 29492K/3276K bytes of memory.
CPU rev number 7
Bridging software.
1 Ethernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
128K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
