VPN load baclancing error message
Feb 29th, 2004
Hi all,
Have configured 2 VPN3030 (v4.1.1) to do load balancing. On the real time log, I received the follow error messages, any idea what causes these:
From the Monitoring, Statistics, Load Balancing, I can see the other peer appearing and disappearing.
47847 02/24/2004 11:09:49.190 SEV=4 LBSSF/46 RPT=4304
LBSSF process timeout for req-type[3], exid[5173], peer[ip-address]
47848 02/24/2004 11:09:49.190 SEV=4 LBSSF/48 RPT=4304
LBSSF Slave processed 1 timeouts
47851 02/24/2004 11:09:50.190 SEV=8 LBSSF/22 RPT=4305
LBSSF sent KEEPALIVE request to [ip-address]
47856 02/24/2004 11:09:53.190 SEV=4 LBSSF/46 RPT=4305
LBSSF process timeout for req-type[3], exid[5174], peer[ip-address]
47857 02/24/2004 11:09:53.190 SEV=4 LBSSF/48 RPT=4305
47858 02/24/2004 11:09:54.000 SEV=4 LBSSF/49 RPT=861
LBSSF process dead peer[ip-address]
47859 02/24/2004 11:09:54.000 SEV=3 LBSSF/86 RPT=861
LBSSF deleted Master peer
47860 02/24/2004 11:09:54.000 SEV=7 LBSSF/55 RPT=862
LBSSF deleted peer[ip-address]
47909 02/24/2004 11:10:28.990 SEV=3 LBSSF/82 RPT=861
LBSSF received GRAT-ARP from duplicate master[mac-address]
47910 02/24/2004 11:10:28.990 SEV=3 LBSSF/84 RPT=861
LBSSF detected duplicate master[mac-address] and going to SLAVE
47941 02/24/2004 11:10:45.190 SEV=7 LBSSF/56 RPT=863
LBSSF created peer[ip-address]
47942 02/24/2004 11:10:45.190 SEV=7 LBSSF/14 RPT=862
LBSSF sent HELLO request to [ip-address]
47949 02/24/2004 11:10:46.020 SEV=7 LBSSF/18 RPT=862
LBSSF received HELLO response from [ip-address]
47951 02/24/2004 11:10:46.020 SEV=7 LBSSF/45 RPT=862
LBSSF received TOPOLOGY indicator from [ip-address]
47952 02/24/2004 11:10:46.190 SEV=8 LBSSF/22 RPT=4306
CM
drolemc Thu, 03/04/2004 - 12:28
  • Silver, 250 points or more
Some of the messages are seen in normal operation and more information is required for zeroing in on the problem. For example, the message "LBSSF received GRAT-ARP from duplicate master[XXXXXXX]" is seen when a system becomes active and the virtual IP address is moved to a different MAC address. A good point to start would be to see if there is any problem observed at all. The messages would mean much more then.
