CSS Interface Redundancy
Mar 2nd, 2004
Is it possible to configure interface redundancy so that if 1 interface on the master CSS fails, it fails over all interfaces configured on the master css, effectively failing over the whole box if there is an interface failure.
d.parks Tue, 03/02/2004 - 08:21
  • Bronze, 100 points or more
If you are running box-to-box redundancy, you can apply the "redundancy-phy" command to the interfaces that you'd like to trigger a failover.
If you are running vip/interface redundancy, the redundancy-phy command does not apply.
jmcglashan Tue, 03/02/2004 - 08:58
We are not running box to box redundancy, We are using virtual routers, we would like to failover all interfaces if one should fail.
stevehall Tue, 03/02/2004 - 09:12
This concept of failing over all virtual routers when a single fails is what is referred to as "fate sharing". Typically it is done by configuring identical critical services to all virtual routers on a CSS. This is sufficient for the vast majority of installations.
There are some rare situations where this will not be the best solution. In software version 7.3 a new feature called "VRID Peering" was introduced. You can tie multiple routers together so they are bound. This would be similiar to HSRP tracking on a Cisco router.
You can read about fate sharing at the following link:
http://www.cisco.com/univercd/cc/td/doc/product/webscale/css/css_730/redundgd/vipredun.htm#1063408
You can read about VRID Peering at the following link:
http://www.cisco.com/univercd/cc/td/doc/product/webscale/css/css_730/redundgd/vipredun.htm#1109382
Hope this helps...
-Steve
d.parks Tue, 03/02/2004 - 09:44
Another way to account for this if your traffic volume allows, would be to trunk both/all of your circuits over a single physical interface. I do this on one of my gigabit interfaces and it works well with VIP/Int redundancy.
