Changing the IP Address of Cisco Call Manager 3.3(2)
Mar 2nd, 2004
Does someone know if I need to re-install the ALL CCM Software in onder to change the IP Address or how can I change? Using the default windows network configurations? Only it?!
Thanks for your support!
Overall Rating: 5 (1 ratings)
dalyd Thu, 03/04/2004 - 07:01
1. You change the address/mask/default gateway under network properties.
2. You change the Hosts and LMHOST files to reflect new address in all the servers.
3. You change the server ip address under the CCM server settings.
4. Reboot all of the servers.
