Warning message
SNMP Trap Test
Mar 3rd, 2004
Does anyone know what is the command to send a dummy snmp trap from a cisco 3600 router to a NMS.
I know Cat 6500 can do it, so I guess there is a way to do it on the Cisco router.
Overall Rating: 5 (1 ratings)
minie Wed, 03/03/2004 - 19:20
  • Bronze, 100 points or more
Though IOS routers can not send dummy trap, it's quite easy to initiate one. Simply enable syslog trap, and exit from "conf t" mode.
Configure this on router
snmp-server enable traps syslog
snmp-server host 1.1.1.1 <-- this is your trap receiver
Now exit. This will generate a syslog messaage, which in turn will trigger a trap.
dkktan Wed, 03/03/2004 - 19:30
Thx for the tip, this is one of the solution I use.
anyway the parameter
'snmp-server enable traps config' will generate a snmp trap every time you exit from the conf t mode.
andy.juventus Tue, 03/09/2004 - 00:39
My config is
snmp-server community XXX RW
snmp-server enable traps snmp(all traps)
snmp-server host X.X.X.X version 2c XXX
But no matter how I enter the conf t mode or shut down an interface , no messages on the host .
Could anybody help me to know why?
{cisco 7206vxr,ios=12.2(8)YW3,the host is where ciscoworks installed}
